some shots right before it went under the knife.
Received 1,675 Likes
Looks good.
Received 19,307 Likes
'20-'21-'22-'23-'24
Sharp car you've got.
why's it matter if i covered my plate? is it really that big a deal? it shouldn't be. im not hiding anything... i just rather cover it.
here is my build thread....
http://forums.corvetteforum.com/c5-f...-together.html
engine:
brand new ls2 block
stock bore/stroke
ls9 head gaskets
callies dragonslayer crank
callies ultra I beam rods
coated diamond pistons
total seal rings
slp double chain
slp high volume oil pump
ls6 intake
arp head studs
arp main studs
arp rod bolts
valvetrain:
AFR 230cc heads with inconell exhaust valves. double springs,ti retainers. 72cc chambers
ls7 lifters
ls1/6 rockers
truinon upgrade
arun cam
blower:
a&a v3 t trim, 2.95 pulley
10 rib setup from arun
custom 15% IW crank pulley from arun
DP flip drive
tial 50mm bov
custom 4in blower intake
fuel:
holley rails
lpe intank with KB BAP
custom fuel system from a member on here
magna fuel 4303 pump on boost switch
60lb injectors(for now)
ecs fuel block
exhaust:
kooks 1 7/8 headers
catless x
corsa catback
drive-train:
hinsion motor mounts
rxt clutch
brand new zr1 transmission
c6z diff
rkt56 offset mounts
suspension:
c6 z06 mono spring rear
c6 z51 sway bars front and rear
i know the motor is far capable of more then what the baby t trim can supply but im going to utilize what i have and just get the car back on the road and broken in and see how it handles etc. i will eventually go YSI in the very near future.
engine:
brand new ls2 block
stock bore/stroke
ls9 head gaskets
total seal rings
slp double chain
ls6 intake
arp head studs
arp main studs
arp rod bolts
valvetrain:
ls7 lifters
ls1/6 rockers
truinon upgrade
arun cam
blower:
DP flip drive
tial 50mm bov
fuel:
holley rails
ecs fuel block
exhaust:
kooks 1 7/8 headers
catless x
corsa catback
drive-train:
rxt clutch
c6z diff
rkt56 offset mounts
suspension:
It wasn't too long ago that some of the infamous Rampart Street station police were busted because they were not only gang members but they were part of a car theft ring.
L.A. County Sheriff Department has had it's share of trouble with the same thing.
Don't get me wrong, I fully support our local leo's and have many friends that are currently in service. But even they will tell you to be careful who you trust.
