[Z06] pfadt transmission mount
Old 01-08-2020, 10:42 AM
Jacob Rose
5th Gear
Jacob Rose's Avatar
Default pfadt transmission mount
Hey guys I am new to the forum and was wondering if anyone has installed the pfadt transmission mount? I am having a bad vibration issue. Any help is appreciated!
Old 01-08-2020, 11:53 AM
neutron82
Support Corvetteforum!
neutron82's Avatar
Received 1,261 Likes on 1,056 Posts
check to make sure the pads on each end are making firm contact with the cradle, there should be shims that came with the mount that can be installed underneath the pads to sandwich them in between the mount and cradle
Old 01-08-2020, 12:03 PM
Jacob Rose
5th Gear
Jacob Rose's Avatar
Okay, I will try that tonight. thanks
Old 01-08-2020, 01:58 PM
zeevette
zeevette's Avatar
Also, make sure your dampener is removed from the diff. I used 1/8" thick pad made from a cut up silicone intake connector to fit between cradle and the main center mount. I've had zero vibration in mine.
Old 01-08-2020, 02:05 PM
Jacob Rose
5th Gear
Jacob Rose's Avatar
Alright, I will also remove that. thanks for the input zeevette!
Old 01-08-2020, 02:32 PM
jjc508520
jjc508520's Avatar
Didn't someone post here that if you used them on the trans that you need to have them on the engine as well?
Old 01-09-2020, 08:11 AM
dskinsler83
dskinsler83's Avatar
Anyone have pics of what they are describing?
Old 01-09-2020, 09:00 AM
feeder82
feeder82's Avatar
jjc508520 (01-09-2020)
Old 01-09-2020, 11:29 AM
dskinsler83
Haha sorry I meant the fixes.
Old 01-09-2020, 02:56 PM
zeevette
zeevette's Avatar
No.
Old 01-10-2020, 09:40 PM
Jacob Rose
5th Gear
Jacob Rose's Avatar
I tried all they stuff. I used the shims and took off that counterweight on the driver side of the diff. I still have a vibration. Could I have bent something while lifting the diff?
Old 01-11-2020, 01:17 PM
killian96ss
killian96ss's Avatar
Do you also have urethane engine mounts?
Steve
Old 01-11-2020, 01:43 PM
Jacob Rose
5th Gear
Jacob Rose's Avatar
No I do not
Old 01-11-2020, 03:11 PM
killian96ss
Originally Posted by Jacob Rose
No I do not
That could be your problem then. I wouldn't personally have a urethane trans mount without urethane engine mounts. If the engine mounts are soft all driveline vibrations will transmit through the harder trans mount causing more vibrations in that area and more stress at the trans mounting point. IMO, It's much better to have urethane at all 3 mounting points to tie it all together.
Steve
To pfadt transmission mount
Quick Reply: [Z06] pfadt transmission mount
