Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 General
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C5 General
General C5 Corvette Discussion not covered in Tech Sponsored by
Bud's Chevy
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 04-30-2013, 12:52 AM   #1
Arts89Iroc
Junior Member
Default Future 2004 Z06 Owner
Hello,
Im looking to buy a 2004 Z06 but I need your guys help on what I should be looking at as far as vin#'s? colors? RPO's? This will be my first vette (A big upgrade from my IROC-Z)
Arts89Iroc is offline   Reply With Quote
Old 04-30-2013, 01:02 AM   #2
Mr.Bill
We Miss You Frank...
St. Jude Donor '12-'13
Support Corvetteforum!
Mr.Bill's Avatar
Location: Reno is so close to Hell you can see Sparks , State Of Confusion
Send a message via ICQ to Mr.Bill
Vin won't tell you a lot, You want to check and see if any service records, Check for oil leaks around motor and around the diff, You also might want to check the codes, You can do this within the car no reader needed.
How toEnter Diagnostic Mode
The "diagnostic display" mode is entered with thefollowing procedure:
1) Turn on the ignition but don't start the engine.
2) Press the "reset" button to turn off any warningmessages
3) Press and hold "options"
4) While holding "options", press "fuel" fourtimes within a 10-second period.
When first engaged the on-board diagnostics go into an "automatic"mode which shows all parameters:PCM-TCS-RTD-BCM-IPC-radio-HVAC-LDCM-RDCM-SCM-RFA. If there are no problems, youwill see "no more codes" on the ICP display.
The computer will show two kinds of codes, "current" and"history," designated "C" or "H". A current codeindicates a malfunction is present in the system whose module is displayingdata. A history code indicates a past problem.
When the screen displays "manual diagnostics," selectthe desired module by pressing the "options" button to go forward orthe "trip" button to go back. Press "gages" to go forwardor "fuel" to go back.
To exit the diagnostic mode at any time, press "E/M". Ifyou want to erase or "clear" codes, press "reset."
Mr.Bill is offline   Reply With Quote
Old 04-30-2013, 01:23 AM   #3
Arts89Iroc
Junior Member
Thanks Mr. Bill, this car is coming from carmax, they want 22,000 for a 2004 blue ZO6 6 speed. I just dont want to buy a fake zo6 and later find out I was duped
Old 04-30-2013, 01:31 AM   #4
Mr.Bill
Mr.Bill's Avatar
Quote:
In the VIN there will either be a G or S, and I don't mean the first G in the VIN. G=LS1 S=LS6. Here are some samples of the two different VIN's.
LS1=1G1YY12G515135627 Non Z06
LS6=1G1YY12S515105773 Z06
Old 04-30-2013, 08:13 AM   #5
CF Senior Member
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Location: Jefferson City, MO Sometimes common sense isn't so common.
If you PM me your e-mail address, I can send you a few Word files that might help you out, including a Corvette Buyers Checklist.
Vetteman Jack is offline   Reply With Quote
Old 04-30-2013, 09:14 AM   #6
JETninja
CF Senior Member
WA Events Coordinator
JETninja's Avatar
Colors...Yellow is the Fastest. ($800 option) Black the Meanest. Blue the Prettiest. Silver the Stealtheist. Red says I wish I had a Ferrari.
JETninja is offline   Reply With Quote
Old 04-30-2013, 09:16 AM   #7
FNFastZ06
CF Senior Member
FNFastZ06's Avatar
Quote:
That's funny right there, I don't care what country you're from.
__________________
'03 Z06 - Black
Comp Cams 281/283 .595"/.598" 112 deg. XFI/XER Cam
LG Longtube Headers with high-flow cats
Vararam cold air
B&M Ripper shifter
LG GT2 Coilovers
Drilled + Slotted rotors, Hawk HP+ brake pads
BFG GForce KDW2s
FNFastZ06 is offline   Reply With Quote
Old 04-30-2013, 09:26 AM   #8
Vega$Vette
CF Senior Member
Vega$Vette's Avatar
How many miles on it?
Vega$Vette is offline   Reply With Quote
Old 04-30-2013, 10:11 AM   #9
Todd157k
CF Senior Member
Todd157k's Avatar
You're going to buy it... and spend lots of time and money modifying it.. headaches getting it right... tuning.. etc.
Just buy mine that's already done.. right!
http://forums.corvetteforum.com/c5-c...s-c-socal.html
Todd157k is offline   Reply With Quote
Old 04-30-2013, 01:34 PM   #10
bikeriderga
CF Senior Member
bikeriderga's Avatar
Funny but haven't you heard,
All Corvettes are RED!!
bikeriderga is offline   Reply With Quote
Old 04-30-2013, 07:14 PM   #11
chasboy
CF Senior Member
Oldtimer
chasboy's Avatar
Art, you can't buy a fake '04 Z. They stopped making the Fixed Roof coupe-only option in 2001, when they introduced the new Z06. The Z has a permanent hard top with a trunk, while the 'sport coupe' has a large rear glass in a hatchback configuration.
chasboy is offline   Reply With Quote
Old 04-30-2013, 10:42 PM   #12
bikeriderga
CF Senior Member
Quote:
Originally Posted by chasboy View Post
Art, you can't buy a fake '04 Z. They stopped making the Fixed Roof coupe-only option in 2001, when they introduced the new Z06. The Z has a permanent hard top with a truck, while the 'sport coupe' has a large rear glass in a hatchback configuration.
Agreed, just make sure it is FRC 01 and above and it has to be a Z06!
I have seen far too many coupes and convertibles with Z06 brake duct coolers, mesh grill inserts, and Z06 badges. It ain't a Z06!!
Reload this Page Future 2004 Z06 Owner
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Pics of my new to me '02 Z06 maroon88iroc C5 Z06 Discussion 45 06-19-2014 01:28 PM
WTB aftermarket C5 air intake tube maroon88iroc C5 Parts for Sale/Wanted 0 03-28-2014 04:57 PM
My widebody C5 Z06 and My gramps movie-car '66 mid-year coupe photoshoot maroon88iroc C5 Z06 Discussion 21 09-06-2013 12:58 PM
Help me decide EOD_Tech Infidel F-Body General Discussion 3 05-26-2013 02:08 PM
Anyone interested in this sub box for an '82-'92? jroc1989 F-Body General Discussion 11 03-29-2013 09:24 PM
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
