[Z06] Z06 Passenger Seat Track
The passenger seat in my '02 Z06 moves back and forth about 1/4", drives my wife crazy. It doesn't bother me because I don't sit there!
Anyway, I pulled the seat out and can see that there is a lot of play in the track. Is anyone familiar with this problem and aware of a fix?
C5 COTM Coordinator
Sounds like the infamous "seat track rocking". Here's a page regarding information on a DIY to get the issue fixed. Personally my driver side had the same problem. The fix below cured it.
http://www.lieblweb.com/c5seatfix.html
You are correct racebum, it is the manually adjusted passenger seat of my Z06, so definitely not the infamous "seat track rocking".
I have removed the seat and pulled a track off. The problem appears to be excess play in the latching mechanism, two metal tabs that engage holes in the sliding track to lock it in position. I am trying to disassemble the track but it is very difficult. The tracks appear to be stamped together during the assembly process.
