[Z06] thoughts on adding oil before track day?
Old 04-18-2013, 10:04 PM
Sprayy
Sprayy's Avatar
Default thoughts on adding oil before track day?
Do you guys do this? Do you drain a liter after or leave it in?
I heard you should add a liter before going to a track.
I'll be attending a 2 day driving school next weekend.
Thanks!
Old 04-18-2013, 10:16 PM
zipity
Support Corvetteforum!
zipity's Avatar
St. Jude Donor '10
absolutely add the extra oil. Even the owner's manual recommends it for racing purposes. Drain it after the track day and refill with the correct amount. Have fun it's a blast on the track!!
Old 04-18-2013, 10:41 PM
Scooter70
Scooter70's Avatar
Yes. You'll probably burn most of it off so there's really no need to drain afterwards.
Old 04-19-2013, 12:09 AM
Hitman227
Hitman227's Avatar
You definitely don't want less oil in the pan during high speed maneuvers, that's bad. Your motor will hate you afterwards like a d*** with no skills.
Old 04-19-2013, 07:12 AM
magneto10
magneto10's Avatar
Definitely do it
It was actually in the vhs tape that came with the car (Not sure if it is in the owner's manual as well)
I haven't tracked mine in a long time- last time I did two weeks later I checked and the oil was back to normal level
Old 04-19-2013, 09:38 AM
Sprayy
Sprayy's Avatar
So add one full quart?
Does it matter if it's the exact oil? Or so long as it's 10/30 synthetic like what's in it.
Old 04-19-2013, 10:54 AM
BrentC5Z
BrentC5Z's Avatar
HAHA! yep.
I'd use the same brand / viscosity though..
Old 04-19-2013, 11:16 AM
JeremyGSU
JeremyGSU's Avatar
Yes, add the extra oil. Myself and others have not drained it afterwards.
I run 7.5 quarts all the time. Mine's a street/track car and I've done 15 track days with it and put 10,000 miles on it. No issues.
I run Amsoil 10W30 Z-Rod.
Old 04-19-2013, 11:29 AM
Sprayy
Sprayy's Avatar
I thanks, I just got mine changed and they used some sort of german synethetic 10w30, place is far away though, so I was just gonna add a quart of mobil 1 10w30
Old 04-19-2013, 01:58 PM
WannaC5Z
WannaC5Z's Avatar
Ok maybe I am a tard but I swear these cars call for 5w30 full synthetic, not 10w30?
Old 04-19-2013, 06:26 PM
AU N EGL
AU N EGL's Avatar
Yup
10.5 qts here or 15w50. have an accu-sump.
10w30 is good, 40 wt racing oil is good too.
5-w30 is ok for one or two events, but if you start dong more go heavier in the oil.
5w30 flows like water and is too thin when hot over 200 for extended times. breaks down quickly too.
so at least 10-w-30
Old 04-19-2013, 07:29 PM
ctusser
ctusser's Avatar
Yea, that's the general purpose recommendation. But oil viscosity can be adjusted for optimization depending on use.
Old 04-19-2013, 08:22 PM
Sprayy
Sprayy's Avatar
i meant 10w30 sorry.
Old 04-20-2013, 12:37 PM
Hitman227
Hitman227's Avatar
It should be the same with 5w30 10w40 or even 15w50, makes little difference. Go ahead put in another quart if it's low, five quarts of 10w40 with one quart of 5w30. You'll be fine, the engine won't complain.
Old 04-20-2013, 12:46 PM
zo659
zo659's Avatar
Originally Posted by magneto10
Definitely do it
This is good info, it does say this in the manual as well!
Old 04-21-2013, 09:50 AM
C66 Racing
Premium Supporting Vendor
C66 Racing's Avatar
Thanks!
GM did recommend running a quart (litre) over for track days and I do this all the time - every session. Uncovering the oil pump pickup point is a very real risk at the track, particularly in high g, high rpm, long left hand turns where the oil moves away from the pickup point and doesn't drain well from the right side valve train.
I've read that the LS6 oil pan allows about 2.5 qts overfill before the oil hits the bottom of the crank which would cause foaming, so 1 quart over is not a problem.
As my car is only track now, I don't worry about the overfill after the event as there is no after the event. For the street, I'd just leave it there.
FYI, I run AMSOIL's Dominator Racing 10w30 at the track, but my car has an aftermarket larger racing aluminum radiator and aftermarket external oil cooler. Watch your oil temps without these extra coolers. My personal rule of thumb is that the viscosity of a 30 grade oil has dropped to dangerously low levels over somewhere about 270F when used in high load situations (like the track). With my setup, my oil temps are typically 245-255F.
If you are going to add Mobil 1 10w30, I'd use the "High Mileage" oil - it has more zinc and phosphorus than allowed by current API SN (or dexos1) specs at 1000 ppm phosphorus, 1100 ppm zinc. Not as good as the AMSOIL Z-ROD mentioned above at 1320 ppm phosphorus, 1440 ppm zinc, the AMSOIL Dominator Racing 10w30 I use at 1474 ppm phosphorus, 1575 ppm zinc, but better than the 800 ppm allowed by the current API SN spec.
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Ordering Information (Retail sales using reference #1206638 benefit the forum.)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
AMSOIL Catalog
Old 04-21-2013, 12:14 PM
Supercharged111
Supercharged111's Avatar
Z Rod doesn't come in 5W30 but is a better oil for the track than M1.
To thoughts on adding oil before track day?
Old 04-21-2013, 01:58 PM
WannaC5Z
WannaC5Z's Avatar
I ran Valvoline full synthetic 5w30 in my 4V Cobra for six years and never had any issues. Makes me a believer in Valvoline the way I beat on that car up to 6,900rpms. Anyone ran this specific Valvoline in their Z?
Old 04-23-2013, 06:16 PM
Hitman227
Hitman227's Avatar
Don't know if you want to run overfill for street, it would be disadvantageous because of additional oil in the pan for street driving.
Old 04-23-2013, 06:46 PM
skyavonee
skyavonee's Avatar
so at least 10-w-30
5W-30 and 10W-30 should be the same at operating temp. If standard xW-30 is too thin for track use, then one should step up to xW-40.
Why?
Quick Reply: [Z06] thoughts on adding oil before track day?
