Anyone else running 60lb injectors in n/a car
Old 04-22-2013, 03:21 PM
spooneralmighty
spooneralmighty's Avatar
Default Anyone else running 60lb injectors in n/a car
Well the car is probably going down to get tuned since its still getting too much fuel with my mail order tune.
Anyway my question is.... Is anyone out there running 60's on a h/c/I car. I'd like to keep these injectors because I already have them but I don't want to go to the tuner and have him not be able to make them work.
The car has a ms4 cam, prc 227cc heads with 62cc domes, fast 90 ported intake, Siemens 60lb injectors, 90mm gm throttle body, cold air intake, long tube headers, slp loud mouth, 255lph pump, Taylor wires and a few small things.
Will I be ok to keep these?
Old 04-22-2013, 04:13 PM
WKMCD
WKMCD's Avatar
WAY too big and could cause tuning issues. FWIW: I ran Ford Red Tops - about 35-36lbs at C5 fuel rail pressure - on my 460RWHP 346CI build. I run Ford Green Tops - about 47-48lbs - in my 577RWHP 427CI build.
Old 04-22-2013, 04:27 PM
spooneralmighty
Texas speed said I should be around 470-480 rwhp. I'm also spraying a 75 shot occasionally
Old 04-22-2013, 05:28 PM
sabastian458
sabastian458's Avatar
My LS2 had those exact injectors, 2 diff tuners have tuned the car over the years without any issues. No need to change them if they still fit your needs.
spooneralmighty
What about green giants? Are they drop in? There 42's
Old 04-22-2013, 05:30 PM
spooneralmighty
Alright that's good news. Just got a mail order tune for money issues. But she's loading up and flooding out on idle so now I'm forced to take it to a dyno tune. Just making sure the 60's can be used so I don't go waisting 400$ on another set of injectors
Old 04-22-2013, 06:42 PM
mustangracer
mustangracer's Avatar
Those injectors will be fine with your setup, I have a lot less mods but occasionally run E85 so I need the extra duty cycle. I have no surging or any other weird behavior.
Old 04-22-2013, 07:11 PM
James2002z06
James2002z06's Avatar
Default I would think that those would
Be to large , I'm running 42 pound injectors with a ton of work done to the car ...
Old 04-23-2013, 09:09 AM
spooneralmighty
Hmmm seems like it's Yoy either like them or hate them. Half had good luck with them
Old 04-23-2013, 10:58 AM
alextz
alextz's Avatar
Did the mail order tune have the injector tables for your injectors?
In my opinion, if you change injectors, you should get a real dyno tune. Mail order tunes are great for bolt ons, cause the MAF and injectors are stock, so you can get real close.
for such a departure from stock as your car, a real tune is in order. First need to get right injector tables, then tune your VE, then idle, then WOT with a wideband. There is no reference point for you with the mail order tune.
Old 04-23-2013, 11:24 AM
spooneralmighty
Texas speed did the mail order tune. I figured it woulda been spot on because I used their heads and cam but it doesn't seem right. It loads up and stalls out. I've been trying to get ahold of them to talk to the tuner but I can't get a call back. I know it's probably going to need a dyno tune I was just wondering if the car can be tuned with these. Don't want to spend 400$ on injectors if I don't have too
Old 04-23-2013, 11:25 AM
spooneralmighty
I sent them a full list of everything in the car.
Old 04-23-2013, 09:08 PM
sabastian458
Mail order tunes are just like mail order brides... Good to get the job do e, but not the ideal thing.
Not every mail order tune can anticipate every variable in everyone's setup. Most are good, some are great, but there will always be some with issues.
Loading up and stalling happening every time and together? Or while driving it loads up and when you come to a stop or neutral it stalls? How big of a cam?
Old 04-23-2013, 09:33 PM
FourG63 97GST
FourG63 97GST's Avatar
Doesn't matter if it's n/a. if you were boosted with these 60s, they'll need to be dialed in the same. If the tuner wants different injectors, find another tuner.
To Anyone else running 60lb injectors in n/a car
Quick Reply: Anyone else running 60lb injectors in n/a car
