Help - Can't downshift from 6th to 5th
Just started happening yesterday while out for a long drive. Tried to downshift from 6th to 5th and it won't go in gear. I can downshift from 6th to 4th to 3rd etc, and I can upshift from 1st through all gears to 6th. Just can't get it in gear downshifting from 6th to 5th. I had to downshift from 6th to 4th and back up to 5th.
Any clues???????????
Are you getting any grinding when you attempt 5th gear? (during up shift or down shift)
If yes, I'd check to make sure your reverse solenoid is functioning properly. If it isn't, the reason you could be having trouble is you're missing the 5th gear gate and hitting reverse.
A shifter alignment would be another thing to perform. No cost and can't hurt.
I have an apt. tomorrow and will have the solenoid and shifter alignment checked.
Thanks.
I'm having the same problem with my C5. I can't downshift from 6th to 5th, but if I skip 5th and go right down to 4th, then I can upshift into 5th.
Did you end up solving the issue on your car?
Then about a month ago, whatever the problem was, worked it self out. Now I have no trouble shifting down from 6th to 5th. I don't know why, but it's OK now!!!!!!!!
If you have yours checked out, let me know what you find.
I decided not to have it checked out but try to live with it rather than spend a bunch of money. I started double "clutching" from 6th to 5th and it seemed to work some of the time, but not all the time.
Did you change your fluid at all before the issue went away?
I also tried double-clutching but it didnt' seem to do anything for mine.
Thanks for your reply. I'm going to try putting in new transmission fluid and then doing a shifter alignment and see if that fixes the issue. I'll report back if that does it.
I just spent this weekend changing my transmission fluid and then I performed a shifter alignment. Although shifting from 1st through 6th has gotten smoother, I still can't downshift from 6th to 5th. When the transmission is cold, I can't downshift from 6th to 5th at all, but once it's warmed up, I can blip the throttle while 6th is still engaged and then downshift into 5th and it lets me. It's so bizzare. Has anyone else had this problem? Before I drop the tranny myself to crack it open I'd like to know if there's a less time consuming fix.
