Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 General
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C5 General
General C5 Corvette Discussion not covered in Tech Sponsored by
Bud's Chevy
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 04-18-2013, 01:40 AM   #1
Cedarberry
CF Senior Member
Cedarberry's Avatar
Default which big brake kit
what kits have you guys found gives the most bang for the buck.
front and back
Cedarberry is offline   Reply With Quote
Old 04-18-2013, 10:33 AM   #2
$$$frumnuttin'
$$$frumnuttin''s Avatar
Location: Less than 1 month to go to hit the 15 year mark.
jerry carguy jerry carguy
I bought a used C6 Z06 set for $1000 last fall. I got the entire kit...calipers, rotors, pads, and lines. I refurbished them to look like this:
Check the C6 Parts For Sale section often....
$$$frumnuttin' is online now   Reply With Quote
Old 04-18-2013, 10:43 AM   #3
jcsperson
CF Senior Member
NC Events Coordinator
jcsperson's Avatar
Quote:
front and back
Street? Track? Or both?
jcsperson is offline   Reply With Quote
Old 04-18-2013, 10:44 AM   #4
skydiven4fun
CF Senior Member
St. Jude Donor '13-'14
Support Corvetteforum!
skydiven4fun's Avatar
skydiven4fun is offline   Reply With Quote
Old 04-18-2013, 01:42 PM   #5
Cedarberry
CF Senior Member
Cedarberry's Avatar
400 hp frc for the street, tracktime down the road. just recently purchased he car and the first mods i would like to do are the big brake kit with widebody in mind for the future. will put on new rims and tires with that.
Old 04-18-2013, 01:43 PM   #6
Cedarberry
CF Senior Member
Cedarberry's Avatar
very nice job on those
Old 04-18-2013, 03:25 PM   #7
red1vette
CF Senior Member
red1vette's Avatar
I went with stoptechs but i do track my car quite a bit.
red1vette is offline   Reply With Quote
Old 04-18-2013, 03:31 PM   #8
jcsperson
CF Senior Member
jcsperson's Avatar
If you're going to do serious track days, you might want to search through the threads on the Autocrossing and Road Racing part of the forum. One of the favorites is the AP Racing/Hardbar T1 kit. It's on my "some day" list.
Click the image to open in full size.
Right now I'm just planning on upgrading brake pads and adding cooling ducts like these:
Old 04-18-2013, 08:14 PM   #9
road pilot
CF Senior Member
Good luck with the cooling ducts on a C-5. It was torture trying
to make the system work. Finally ended up using 2 electric blowers
hidden behind the front bumper. All is well and I can turn them on and off from a switch. Good luck on your cooling project.
road pilot is offline   Reply With Quote
Old 04-18-2013, 10:33 PM   #10
robert miller
CF Senior Member
robert miller's Avatar
Default ttt
I have a set of the big BREMBO cost over 7,k new. These or RED a guy had a set of BLACK one's for sale a few weeks back...will sale for 4300.00. Reason for the pull off is drag pack with 15,s on the rear. Robert
clif, sold a kit in here, mine are a full set front and rear just like what he had for sale. rotors brackets to mount them plus the SS brake line for the car also they come that way. Only diff is these I have or RED...Robert
robert miller is offline   Reply With Quote
Old 04-19-2013, 01:58 AM   #11
JETZ
CF Senior Member
JETZ's Avatar
Brembo, 15'' 8 piston F, 14'' 4 piston R
JETZ is online now   Reply With Quote
Old 04-19-2013, 02:17 AM   #12
Cedarberry
CF Senior Member
Cedarberry's Avatar
Quote:
very nice, thanks for the post
Old 04-19-2013, 03:04 AM   #13
WalterSobchak
CF Senior Member
WalterSobchak's Avatar
W/Hawk pads....Awesome! It should have came this way.
WalterSobchak is offline   Reply With Quote
Old 04-19-2013, 07:14 AM   #14
jcsperson
CF Senior Member
jcsperson's Avatar
Can you post some pics of that when you get a chance?
Old 04-19-2013, 11:32 AM   #15
Cedarberry
CF Senior Member
Cedarberry's Avatar
how many of you are runnin 19inch rims up front and 18 in the rear to clear the big brakes.
isnt there a problem with this set up, as far as the car recognizing wheel
/tire height?
Old 04-19-2013, 12:04 PM   #16
WalterSobchak
CF Senior Member
/tire height?
Running 18/19 to clear my z06/GS brakes.
Car has no idea what size your rims are. You just need to make sure your tires are the right size for your rim to give the wheel stock diameter. Or you can change the wheel diameter in the pcm if you have an appropriate tuner.
Old 04-19-2013, 01:47 PM   #17
robert miller
CF Senior Member
/tire height?
On the brembo you have to run 19,s up front on the bigger rotors and brakes from brembo. I have 19,s in fron and 18 in rears. Plus my 19,s from CCW SP 500 not much room at all still. Hope this helps you. Plus you have to make sure your rims are for a big brake kit also. Robert
Old 04-19-2013, 02:31 PM   #18
'Shifter
Gimme fuel, gimme fire...
St. Jude Donor '08-'09-'10-'11-'12-'13-'14
NCM Member '09
'Shifter's Avatar
I went the C6 Z06 way so that replacements for anything are OEM, and should be around a lot longer than some aftermarket companies. (also, I got an employee discount..)
Eventually, I swap these StopTech Sport Stops for Coleman 2-piece though...
'Shifter is offline   Reply With Quote
Old 04-19-2013, 02:49 PM   #19
$$$frumnuttin'
Not all 18s will clear the calipers! I was running spyder knockoffs (18x9.5s up front) and they were way off for clearance...had to buy new wheels to complete the mod.
Reload this Page which big brake kit
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Meth kit Caveboy C5 Forced Induction/Nitrous 3 05-06-2014 09:04 AM
WTB: Nitrous Express Kit ZO ZICK C6 Parts for Sale/Wanted 1 03-25-2014 11:55 PM
WTB-Complete Meth Kit winters97gt C5 Parts for Sale/Wanted 1 09-10-2013 08:29 AM
WTB Nos Kit for 85 shamdave C4 Parts for Sale/Wanted 0 04-25-2013 06:23 AM
C3 Body Kits rrrrrpppp C3 General 3 09-30-2012 10:20 PM
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
