Headlight motor repair
I need some help guys. I found this guy on eBay carguy8t8 who rebuilds headlight motors for 75 bucks or 110 with the bronze gears. He has really good feed back. Was wondering if anyone else has used him
Location: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
Why not just rebuild your own with brass gears for 45 each?
http://www.rodneydickman.com/corvette.html
http://www.bfranker.badz28.com/headlightfix/
Received 19,219 Likes
'20-'21-'22-'23-'24
But to answer your question, I've never heard of that gentleman so can't give you any feedback on his work quality.
Rodney also sells braces which are great after the headlight motor's top plastic plate is re-glued on.
Do it yourself, it's an easy fix. Since you've done it before, you know that. Now, can you hear the motor running? Since it doesn't go up or down, you may not be getting power. If the motor is running, either the gear is comepletely stripped (rare) or the cover has come off. Have you manually opened it to see what's going on under there? That would be my first move.
Yes the motor runs. I've replaced them with the depot lights. My wife hates them wants the factory ones back no I haven't opened them up yet. Going up in the attic to get them. Thanks everyone
