99 c-5 headlight cover adjustment
need to adjust my drivers side headlight cover.I need to move it about a 1/4 inch towards the opposite corner.What screws get loosened or is there more to it then that?
Is it already sitting at the correct height??
Not much provision for side to side/corner to corner adjustment.
--Try This Quick Answer/Quick Fix--
-remove phillips screws holding headlight bezel in place and remove bezel.
-loosen the four torx screws holding lid in place and see if this minimal movement is enough to adjust lid properly.
-reverse order to tighten
This has worked for me for the few minor side alignment adjustments I've made, not sure it was 1/4" tho...
The only other adjustments are height adjusters at all four corners under the lid. They are white plastic hex-head screws that raise or lower the each corner to align the height of the lid even with the adjacent body panel/hood/bumper cover...
I might have a few pictures floating around if needed...
hthy
hthy
Received 19,309 Likes
'20-'21-'22-'23-'24
These might help:
