C5 Headlight "Four-On" Harnesses @ JWM- Double your light output!
#85
I have replaced my headlight housings with the ACA kit with drop in HIDs in the low beams and halogens in the highs. In order to get them to work properly I had to use the wiring kit that came with the ACAs. Will this harness still work in my situation? Please advise.
#86
Banned Scam/Spammer
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17,'19,'22
The original ACA kit included the 4 on function with the harness that was included. If wired properly you should already have this.
If your lows don't stay on with the highs it should work for you.
#87
Gotcha, thanks for the reply. I was thinking that maybe this would allow for the fogs to stay on as well as the lows and highs. I had to go check and you're correct...I already have the 4-on function but my fogs turn off with the highs on. Oh well...it was a nice thought for a second there.
#88
Banned Scam/Spammer
