iPod/AUX input into factory radio write up for $3
#61
SEC5 - I would go ahead and test 4 and 5 as others have had luck. Worst case, you pop it back out and go with 1 and 3. On my radio, I was able to plug everything in (except antenna) with it hanging out of the dash upside down, so I could actually live test the wires. May or may not do the same on yours.
Wolf - Do you have a CD player in the head unit, too? That's 1 and 3 on mine. I don't know about the cassette. I'd probably stay away from it, but I guess it's possible to have a blank tape running. The key is you've got to activate the component you're hooked up to.
I had no bleedover even when playing a regular cd as I think the mp3 jack if properly hooked up, completely disconnects the signal. I made a silent cd just in case and since it's not one to listen to anywhere else, won't "grow legs" and leave the car.
I used phone butt connectors (radio shack) to help repair the damage I did to mine. They are much easier than soldering and can give you quick feedback. A pair of real wire strippers from radio shack or a computer store (small for this area) will make life much easier.
#62
1 more quick question.. The ground!! Should this be a speaker ground,chassis ground, or a 12v (-) ground??
I assume it is just a very good chassis ground, but if it would be less interference using a -12v ground I can go that route too!!
Thanks again, should have this wrapped up today!!!
SEC5
#63
So, I am working on this mod, and reading all the mixed results. I had an opinion or 2 about the mis haps from the "newer" radios..
I AM working with a newer radio, and I noticed;
First, that there is no circuit board on top, I believe it is underneath, so in the instructions when it says to put certain color on harness side, and other color on opposite. End (sorry don't remember exactly how it's worded), but on the newer radios, since the circuit board is underneath, then what you are looking at is opposite from seeing it circuit board on top, so another words, if the green wire was supposed to go closest to the harness on board, when you cut wire on newer unit, it would actually be backwards, since the connector for the board is not visible as on the older, circuit board on top radios??!! Not sure if that matters or not.??
ALSO, and probably just as guilty,,, is the actual Jack!! I am sure these come in a variety of lay outs... This particular one is designed for when there is nothing plugged in, it creates a default circuit, still allowing original signal o pass through. If they have wrong AUX input jacks, it will also not work right because the plug doesn't disconnect the source like it should!
Just trying to get the (some work some don't) issues behind us while I am working on this!!!
I was planning on putting 1/8 jack in the faceplate, but now have decided to use center console since there is a 12v charging plug in there!!!!!
This is a great and easy mod,,,,,, keeping fingers crossed it works great after all hooked up!!
Let you all know how it turns out!!!
Thanks again to thread author, fantastic Mod!!!!!!!!!!
#64
I grounded my mp3 jack to the larger silver radio cover screw. No other grounds were needed for me. SEC5 you're seeing the same thing I did when I took it apart. I just left the #1 and #3 wires cut and stripped, then tested the mp3 connections before proceeding to make sure I was feeding it the right way.
#66
OMG.... My soldering skills SUCK!! From the pics this part doesn't look so small!! But it is!! Ten the 5 little tabs! Anyways, did 4 perfect, on the 5th, overheated, and metal piece came floating out of the plastic casing. (Never knew how people soldered things in a plastic casing?) Good thing it's a <$3 part! On my way back to Radio Shack, I'll pick up 2 this time, if I don't F this one up, I can return the spare!!
Let ya know how it goes!! On another note, I added small alligator clips to the other side of the cable temporarily so I can test the 4&5 wires without having to perform a balancing act??!!!!
SEC5
SEC5
#68
Finally finished this MOD!!! Thanks for all the help & info!! Just an FYI, I have a 2000 Vert no CD Changer. My radio also does NOT have the circuit board on top. So I assume this is the newer radio??!!
Anyways... I tried 4&5 first, because I really don't have ANY CD's lying around anymore, and I just wanted to tap into the radio signal!! But NO dice, in one configuration I got an error code, and the CD was acting funny, so I think these have something to do with the CD also.
Went back to the work table, repaired 4&5, and cut 1&3.
BINGO!!!
Works like a charm, but I do HAVE to have a CD in, so it IS hooked to my CD input! Couldn't get it on the radio, but it is what it is.
I LOVE this mod, I will mount jack in console (haven't done that yet), so it is close to the power supply, and so I can hide my iPod in the console!!
However tonight I was testing it out with my iPad, and Hmmmm, it sure has me thinking about another MOD!
Thanks again, love the "Factory" look!!!
SEC5
BINGO!!!
SEC5
#69
Thank you guys again with the " newer" style radios for adding your experiences to my original post! I really is a reasonably easy and definitely an inexpensive mod that I use every time I drive my vette!
Tyler
Tyler
#71
Just did mine - works great! #4 & 5 wires for me - '98.
I mounted mine just ahead of the center console. I also used a cheap $1 female/female cat5 connector from the dollar store so that it has a quick disconnect if and when I pull the console apart!
The only thing I'm disappointed with is that you have to pull the 3.5ml plug from the socket or else the sound from the radio/cd only has the treble on - no bass at all. I was hoping to just have one end of the 3.5 cable hanging to make for an easy plug in.
Thanks so much for this mod!
ArmchairArchitect (04-04-2018)
#73
Didn't think about that one!!
But no issues when I just use selector and switch to FM (or Radio).
Since I only have 1 CD, and I don't listen to it, it's not too big of an issue, when my iPod is not plugged in, I just switch to FM.
HOWEVER, in the OP, he mentions making a "blank" cd!
I think this is a great idea, and plan to do this as soon as I am physically able! (Had back surgery 4 days ago)
Great looking mod, I like placement, and quick disconnect for jack!!
SEC5
#74
#75
