Radio wiring help
Old 03-13-2013, 09:52 PM
Jrockk
Jrockk's Avatar
Default Radio wiring help
Hey wondering if anybody can help I put a aftermarket radio in car and read that I should put the red power wire to a yellow wire in passenger footwell
It said there's 3 wires taped off there. A yellow black and orange
So I found a set of wires those colors already cut with tape on them my question is a are these the wires I posted pic
And b I hooked red wire on radio to the yellow like I'm supposed to and nothing happens but if I touch red wire to yellow on harness it turns on
So is there a fuse down there I can just hook up to or another wire
Old 03-13-2013, 09:54 PM
Jrockk
Jrockk's Avatar
The wires I hooked to are the ones coming out of that harness hooked into the panel in pic
Old 03-13-2013, 09:58 PM
TheRadioFlyer
Supporting Vendor
TheRadioFlyer's Avatar
Typically from the radio, the yellow wire is the main power wire and the red wire is a 12v (+) signal lead (on with ignition only) If you have a volt-meter, this should help you find which wire does what.
Old 03-13-2013, 10:12 PM
65GGvert
65GGvert's Avatar
Received 3,232 Likes on 2,309 Posts
Most newer radios require two 12v sources, one for the memory and clock and the other for power (only with key on). Generally the radio won't play if you don't have both. You can hook both radio wires to the same switched 12v, but every time you turn off the key, you'll lose station memory and time will reset.
Old 03-13-2013, 10:13 PM
Jrockk
Jrockk's Avatar
Right so on the roem-vette1 it says to hook yellow to yellow and the red has to go to a triggered power source so in another thread I read about the yellow wire in the passenger footwell but its not working
Old 05-10-2013, 08:53 PM
1 SIC Z
1 SIC Z's Avatar
Did you find the answer to this?
Old 05-10-2013, 08:56 PM
Jrockk
Jrockk's Avatar
Lol yea apparently there wires for accessory from factory but I couldn't get them to work
Old 05-10-2013, 08:59 PM
1 SIC Z
1 SIC Z's Avatar
So did you ever get your radio wired up?
Old 05-10-2013, 09:21 PM
Jrockk
Jrockk's Avatar
Yes just ran wire to fuse box in passenger footwell
Old 05-10-2013, 09:30 PM
0Double D Mods
Former Vendor
Support Corvetteforum!
Double D Mods's Avatar
St. Jude Donor '12-'13
the yellow will work as long as you didn't blow a fuse.
or
have a 2004 where there is no wires in the footwell
Old 05-10-2013, 09:41 PM
Jrockk
Jrockk's Avatar
or
What fuse would it be
Old 05-10-2013, 09:45 PM
0Double D Mods
Former Vendor
check 7 and 11
Old 05-10-2013, 09:46 PM
Jrockk
Jrockk's Avatar
check 7 and 11
Old 05-10-2013, 09:49 PM
1 SIC Z
1 SIC Z's Avatar
Can one of you post a pic of how this is supposed to look like after it is installed. I am sure it is pretty simple but this would help out.
Thx
-John
Old 05-10-2013, 09:54 PM
0Double D Mods
Former Vendor
also make sure you are connecting the red on radio and not the roemvet1
To Radio wiring help
Quick Reply: Radio wiring help
