Will these wheels work
Throwing around the idea of selling my sp500 and going with flared rear fenders. These just posted up locally. Will they work?
http://kansascity.craigslist.org/pts/3665829214.html
It'll be a harsh ride. Also find out what the weights are. Performance will suffer with the extra weight of the bigger wheels and tires.
as stated earlier off-set is critical in determining. 25mm profile is quite slim, low, harsh...you may want to reconsider, rear width of tires is quite wide unless your considering wider rear fenders.
