Can I use different tires?
I'm currently running pilot sport on my 99FRC The driver side front tire has some damage on the sidewall. Can I replace the two front tires to something other than run flats and run a combination of run flats on the rear and non run flat on the front. This tires have less than 15k on them. I hate to even have to replace the fronts,but got to think of safety.
If they have less than 5k, why not just buy one tire of the same type to replace the damaged one?
I wouldn't mix run flats and non run flats but thats a personal thing. The run flats have very stiff sidewalls although the PS AS ZPs are not as stiff as the OEMs.
It can only affect the handling adversely if you do.
Mind you, if you do, having the stiffer sidewalls on the back is possibly the better option. I'd guess understeer but the guys who track their car are better qualified to comment.
JMHO.
JMHO.
Absolutly NOT ! Radials in front and stiff runflats in rear is a disaster waiting to happen,especially on a corvette. You could get away with it if it were the other way around but I wouldn t reccommend it.
In that case, you're going to have to evaluate your situation. How badly do you want to get rid of the run-flats? How much tread is left on the rears? You can put run-flats on the front now, but then you'll be in the same shape when the rears come up for change. Or, you can bite the bullet now and buy all four non-runflats. If you don't mind running run-flats, your cheapest option is going to be either find a used runflat that matches what you have, or replacing the fronts with run-flats.
Personally, I'm just a cruiser, so I wouldn't mind mixing the tire types temporarily until the rears were needed. But you may drive your car more agressively or in different weather conditions than I do.
OP-I hate to even have to replace the fronts,but got to think of safety.
Really? You mention safety and then want to go cheap on tires??
You can get 4 non runflats for under $700 installed!!!!!
Dave
Dave
Where do you see Cheap! You must be reading someone elses post. I just wanted to know if I could mixed them. If i can't I would by four new ones. The Pilot Sport A/S Plus ZP where more than $700. If I was cheap I would run the tire with light cut on the sidewall.
I see a lot of people saying they wouldnt mix the 2 but no facts or experience as to why. Do any of the naysayers have facts about what would happen if they were mixed? One guy posted that he did it without issue which sounds about right to me.
OP: if I were you I would do research elsewhere, maybe contact a tire company to find out for sure. Here you are mostly going to get opinions from people who really dont know. For the record, I also do not know.
I see a lot of people saying they wouldn't mix the 2 but no facts or experience as to why. Do any of the naysayers have facts about what would happen if they were mixed? One guy posted that he did it without issue which sounds about right to me.
OP: if I were you I would do research elsewhere, maybe contact a tire company to find out for sure. Here you are mostly going to get opinions from people who realldon'tnt know. For the record, I also do not know.
When I bought my 03 it came with GY run-flats on the back and GY non run-flats on the front. I have had no handling problems at all. I auto-x mine and am a region champion, tho I would not reccomend run flats for this but that is what I had and used until they wore out. I also had the car up to 140mph at Talladega with no problems other than my wife screaming, the 33.5 degree banking is something else. I now have a set of Michelin Super Sports on but don't have enough miles on them to really evaluate how they handle yet but they are quiter than the GY's
I'm in the same boat and I believe my back tires are OK, but I need fronts. I would love to get 1 or 2 more seasons out of the back if I can, so I want to go non run flats on the front only.
I'm not cheap, but frugal. I hate paying the hostage fee of run flats and will for sure change to non run flats for sure and I hate to replace all 4 when only 2 are needed.
So no one has any proof of this being wrong other than their opinion?
I changed my front to non run flat and have no issues what so ever. I drive my car semi aggressive at most, 680 mile so far on them an all is well. The noise from the run flats on the back are very noticeable now.
2 comments and an example
1. I've run mixed tires, runflats on one axle and non runflats on the other. no problems on the street.
2. the only place i would see this posing a problem is on a track where handling characteristics and traction would be changed, not in a dangerous way but enough to drive accordingly. Also, if you track your car (auto x, HPDE) or drive that aggressively, you shouldn't be using runflats anyway.
In drag racing, they say never run a bias ply slick in the rear with radials up front. I run a pair of bias ET streets with gto skinnies with radials and it runs smooth and straight. I know many guys at the track every weekend that do the same and have never had an issue.
St. Jude Donor '09-'10, '14
Tires are tires, one you can drive on semi flat, the other you can't. When full of air they both have traction. That's what you want.
My common sense meter tells me you can use whatever combination you want so long as they hold air and have traction.
They used to say you couldn't run radials with bias ply tires but I saw it done many times.
LOL.....common sense meter. Some people are still trying to figure out what it's for!
I been mixing forever, I require different characteristics between the front and rear.
it does affect handling in comparison to have all four, since the front and rear will have a different "feel", but you will learn your car. It also depends on the type of driving you do, most people don't do that "type" of driving to even notice.
