[Z06] I'm confused about what upgraded lights to get
I want to update all the lighting for my C5Z but I don't know what ones would be the best deal and easiest to install.
I want tail lights, headlights, reverse lights, corners, etc..., all of em'.
Can someone give me a good, clear answer?
Thank you!
Thank you!
Can't go wrong with JW or RadioFlyer. I went with both vendors. Got ACA mains and LED tail lights from RadioFlyer, and clear corners from JW. Both great vendors, both excellent products. They both run specials on the forum from time to time, keep an eye out for them!
Supporting Vendor
Radioflyer's "Night Flyer" Package
The kit includes:
- The Radioflyer ACA Bi-xenon headlight kit: This is the most powerful headlight option for pop up headlight system retaining the factory look during the day and turning night into day after sunset.
- HID fog kit: Convert you halogen fog lights into something useful with a simple plug-and-play 35w HID kit that runs off the factory harness. (Since you Have a ZO6, this can either be upgraded to the complete fog kits for ZO6 for +300 or you can delete the HID fog kit from the package and discount $75 from the package price)
- Clear Corner lights with LED strip modification: Your choice of clear corner lights with white or amber LED strip modification
- Amber LED turn signal bulbs: pure color, lower power draw and best of all won't melt your turn signal housings. (upgradeable to Gen 3 switchbacks upon request)
- Hyperflash Harness: The safest, easiest plug-and-play way to defeat hyperflash caused by low current draw of LED turn signals. Installs in minutes under the driver's dash
- 194 rear markers: Simple and effective red LED Marker bulb for your rear side markers.
- Radioflyer Halo tail lights: The most popular LED tail lights for the C5 with the Radioflyer Halo mod included!
- Adjure Reverse lights with 20w LED bulbs installed: The Brightest factory-wattage reverse lights on the market. Over 2000 lumens of light to help you see down dark driveways.
- LED tag / exhaust plate lights: The LED tag light strip provide a uniform cool-white glow on your license plate while the exhaust plate light illuminates your exhaust plate. Both are plug and play using your factory tag light sockets.
If you have any questions, email me at Radioflyer97@gmail.com
Supporting Vendor
Yellow is suggested for fog lights in adverse weather (rain/fog) use particularly with projector fog lamps. It's particularly effective because the human eye can see more clearly with yellow particularly when visibility is poor.
White is suggested for headlights on the other hand because white light accurately reflects the color of surfaces which helps with distinction between different objects.
