Driveline cradle/stand info?????
Hello can someone give me a link to where i can see a stand or cart someone made to hold the complete driveline assembly . I seen one on here before but cant find it now, and i have search here and google. I am needing to build one and would like some info. Thanks
You're removing just the transmission and tunnel right? Just a regular transmission jack is fine. The front of the driveline is not the heavy, most of the weight is at the transmission and diff and usually will stay balanced when you pull it out.
From a sale add on this forum around 07/12 I saved these photos.
Attachment 47718276
Attachment 47718275
Attachment 47718276
Attachment 47718275
Received 19,391 Likes
'20-'21-'22-'23-'24
Just saw your comment regarding the stand
Thank You
