Anybody running 275's on the front AND rear?
Old 02-20-2013, 09:21 PM
TorchRedRocket
TorchRedRocket's Avatar
Default Anybody running 275's on the front AND rear?
Would this be stupid? I was thinking of running a 265/35/18F and 275/40/18R. And then I got to thinking, why not run a 275/35/18 up front? Would there be any adverse affects to this, handling-wise, running the same widths at all 4 corners? Has anybody done this?
Old 02-20-2013, 09:55 PM
renegad44
renegad44's Avatar
Location: This is not a Song, It's an Outburst: Or, The Establishment Blues; Sixto Diaz Rodriguez
I don't see any reason why you couldn't run 275's front and rear, but I would do 35's. I'm running 18x10's front/rear, 275/35 front, 295/35 rear. Mine is lowered on stock bolts and I have no problems with 275's up front.
Old 02-20-2013, 11:16 PM
mikes1hog
mikes1hog's Avatar
Oldtimer
No problems with the electronics? No warning signals on the dash? I thought that you needed to maintain the stagger between front and rear to keep those electronic gizmos quiet. It would seem that with the same size tires and wheels that the stagger would be lost. If all is OK, could you explain how that is ? Thanks.
Old 02-20-2013, 11:39 PM
TorchRedRocket
275/40/18's are 1" taller than 275/35/18's. Thus, maintaining the front/rear stagger...
Old 02-21-2013, 08:07 AM
mikes1hog
mikes1hog's Avatar
Oldtimer
I agree with your setup. Renegad44 suggested 35's front and rear.
Old 02-21-2013, 09:51 AM
renegad44
renegad44's Avatar
I don't know, I guess my reasoning is if you have same size wheels, and same tire height, it shouldn't activate ACH. Follow the link below, Toque is pretty damn good with wheel and tire sizing, if you notice, he's running 30/19's front and rear, same as me, except mine are 35/18's front rear. There are other guys running wheels/tire height the same.
As far as computer problems, not a one.
http://forums.corvetteforum.com/c5-g...5-30-19-a.html
Old 02-21-2013, 10:07 AM
roscoe118
roscoe118's Avatar
Originally Posted by renegad44
...Toque is pretty damn good with wheel and tire sizing, if you notice, he's running 30/19's front and rear...
Toque may be running 30/19 front and rear (I do as well), but I gaurantee that they are not the same widths! I'm running 275 front, and 305 rear, widths and I'm sure he's doing at least the same (maybe 315 rear).
You can not run the same height tire on the front and rear without the AH complaining...
Old 02-21-2013, 10:16 AM
renegad44
renegad44's Avatar
Excatly, just as mine are 275/35/18-F, and 295/35/18-R, with no problems at all....
The OP want's to run 275's front and rear on 18's with staggered heights.
Old 02-21-2013, 10:22 AM
roscoe118
roscoe118's Avatar
OK I guess this statement confused me...
Old 02-21-2013, 11:37 AM
Humy
Humy's Avatar
My WS6 T/A had 275 on all fours and I hated it, uneven road would pull me all over over the place, I like 245s in front
Old 02-21-2013, 12:27 PM
STALION
STALION's Avatar
Location: ALL governments are legalized mobsters, so doesn't matter where I live :(
Rule of thumb I believe is 1/2 and more height difference between front and back if I'm not mistaken. As for running 275 width up front is not an issue what so ever.
Old 02-21-2013, 01:00 PM
photonhunter
photonhunter's Avatar
I've been running 275/35Z R18 on all four Z06 style wheels for most of my FRC's life.
I know what 'the rule' is, but it hasn't messed up my handling.
I don't know why I haven't suffered the consequences, I'm just putting forth a data point.
dan k.
Old 02-21-2013, 08:51 PM
TorchRedRocket
Gotcha.
Hmmm I wonder if the wider fronts are more prone to this? My stock sized goodyear runflats were HORRIBLE when it came to darting and following road grooves on the highway.
dan k.
Do you not have active handling? I'm wondering if that's why you haven't had issues?
I know the tire sizes (overall diameter) in question will work together. Basically what I am asking is if I will have any adverse handling side-effects from running a wider tire on the front that's as wide as the real, as opposed to the OEM sizes of 30mm narrower up front.
Old 02-21-2013, 10:20 PM
_zebra
_zebra's Avatar
275/35-18 is the same overall height as a 245/45-17, so you're good
Old 02-21-2013, 11:14 PM
nj02vette
nj02vette's Avatar
Location: Marlton. Increasing performance one speeding ticket at a time! NJ
Wider tires up front will definately make you pull more. I've heard that wider tires on the rear mitagate that, but don't have any experience. Overall, I think you'll be fine but be prepared to find every grove in the road.
I'm running 275/35/18 on the front.
Changing tire diameter has an affect on the spedometer and AH measurements. One of the things the computer does is it looks at the difference between front and rear tire revolutions and if it determines that one is spinning faster than it's supposed to relative to the others, it then activates traction control.
However........if the correct sized tires have been programmed into the computer, then I believe all is OK.
Old 02-22-2013, 10:02 AM
roscoe118
roscoe118's Avatar
I was thinking the same thing. Perhaps and older ('99?) FRC that does not have AH...
I think nj02vette summed it up pretty well. You can expect to feel more groves in the road. I clearly noticed this when I went from the stock 245s, to the 275s, up front. No big deal though. You'll get used to it quickly!
Old 02-22-2013, 12:24 PM
FormerlyFiero
FormerlyFiero's Avatar
Oldtimer
Generally speaking, most 50-50 balanced cars have narrower tires in the front to lessen the chances of oversteer, even without factoring in active handling. They were purposely engineered for the "average" driver so as not to let them get into trouble (plow off some speed). Tighten up a Fiero too much and it will spin like a top about it's axis. (before the days of electronics). I'm thinking that tire diameter is possible for the computer to calculate, using the ABS sensors, the width isn't.
To Anybody running 275's on the front AND rear?
Old 02-22-2013, 12:54 PM
photonhunter
dan k.
No, the FRCs did not have AH, just TC.
I've heard that TC doesn't take the front-to-back tire sizing into consideration. Don't quote me on this, it's just hearsay evidence. <g>
dan k.
Old 02-22-2013, 05:27 PM
mikes1hog
mikes1hog's Avatar
Oldtimer
I
Now I am confused. Why would you want to get used to feeling the grooves in the road? Quick or not? I was ready to do 18's all around with the wider tires, but I'm not so sure now. At my age, there plenty of shxt to get used to; I found the right tires on my Harley to avoid feeling the grooves in the road (I refused to "get used to it")-why would I want to feel the grooves in my Vette?
Old 02-22-2013, 05:37 PM
Mr.Bill
Mr.Bill's Avatar
Location: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
I have 265-35-18 front and 295-35-18 rear with no driving issues at all.
Quick Reply: Anybody running 275's on the front AND rear?
