Vibration at idle, in gear
Old 11-18-2011, 06:36 PM
RaiderNick
RaiderNick's Avatar
Default Vibration at idle, in gear
I have a vibration at idle when in gear. It's worse with the AC on. It also seems more prevlent once the engine warms up. It goes away when the idle hits 525 RPM. Sometimes it goes away by just turning the AC off. Also, I had the alternator replaced about 1500 miles ago. I had the vibration prior to the alternator being replaced. I have done a search, but haven't found a post with quite the same symptoms.
2002
A4 Coupe
35,000 Miles
Thanks in advance.
Old 11-18-2011, 07:04 PM
Big Duk
Big Duk's Avatar
check your belts & idler assy. (tensioner)
Old 11-18-2011, 08:11 PM
RaiderNick
RaiderNick's Avatar
The idler was my first thought. I had the serpentine replaced with the alternator.
Old 11-18-2011, 08:20 PM
RaiderNick
RaiderNick's Avatar
I guess the other question is should I replace both assy's while in there?
Old 11-18-2011, 09:26 PM
Pewter2000C5Vert
Pewter2000C5Vert's Avatar
Same problem when brake pedal is depressed and I go into gear it happens, Reverse is more of a problem then drive. And AC does add to the problem. No issues when I am off of the brakes and rolling.
Old 11-18-2011, 09:35 PM
RaiderNick
RaiderNick's Avatar
Good point. Mine does the same as soon as I get off the brake pedal
Old 11-18-2011, 09:56 PM
Silverbullet00
Silverbullet00's Avatar
Location: Norman Oklahoma - The Only State in the Union with no Blue Counties!
2002
A4 Coupe
35,000 Miles
Thanks in advance.
If you car's idle is at 525 rpm I am surprised it will idle at all. You would have a heck of a shake. I have a cammed LS1 that shakes some. Idle set at 850.
Old 11-18-2011, 10:06 PM
RaiderNick
RaiderNick's Avatar
I did wonder if the idle is low. It idles at 500 with AC on
Old 11-18-2011, 10:49 PM
Silverbullet00
Normal Idle is 750+/- When you turn on AC your car's computer should bump the rpm up 50 rpm. If your tachometer is showing 525 on start up and 500 with AC, that is not right. Get a dealer, buddy with a HP tuner, Auto Zone dude etc. to bump up your idle speed to 750,,,bet that solvles your stated problem.
We will be waiting if it doesn't,,,,let us know!
Old 11-19-2011, 11:44 AM
RaiderNick
RaiderNick's Avatar
Is the proper idle different between a M6 and an A4?
Old 11-20-2011, 10:15 AM
RaiderNick
RaiderNick's Avatar
Bump
Old 03-07-2012, 11:17 AM
Laserdude
Laserdude's Avatar
Default Same problem
I have exactly the same problem with vibration at idle in gear. RPMs are around 500 and I get a vibration. A local shop I use has changed the tentioner twice. It goes away for a day or two and then comes back.
Did anyone find a fix?
Thanks, Ron
Old 03-07-2012, 11:24 AM
Oh 2 Fun
Oh 2 Fun's Avatar
St. Jude Donor '09, '13, '15
I wondered about that low idle number myself. Thought it migh be a typo it was so low.
Question now is what is causing your idle to go so low.
Old 03-07-2012, 12:30 PM
corvettebob1
corvettebob1's Avatar
Your idle speed is correct, check the pulley on your alternator it should be a clutch type if not that is your problem.
Old 03-08-2012, 12:09 AM
tripleblackvert
tripleblackvert's Avatar
I dont have the low idle problem but I do have the problem with the squeaking/sqealing so im going to replace the belt, idler, and tensioner
Old 03-08-2012, 08:56 AM
Dagget427
Dagget427's Avatar
Not sure if this will help or not, but you might want to check for the "harmonic balancer wobble" that these things are known for. It may not be the cause of your low idle vibration, but if it does "wobble" it can cause the belt to wear out and cause the squealing others have mentioned.
Old 03-12-2012, 10:24 AM
Laserdude
Laserdude's Avatar
Thanks for the ideas. I'll check them out.
To Vibration at idle, in gear
Old 03-12-2012, 12:10 PM
RaiderNick
RaiderNick's Avatar
I had the alternator replaced about 1500 miles ago. I had this problem prior to having the alternator replaced. In other words, replacing the alternator did not fix the issue. I'll be getting the car out soon with the weather getting better and taking it in to see what the service people say.
Old 03-12-2012, 12:57 PM
sainthinds
sainthinds's Avatar
clean your throttle body probablly idleing too low ? you know how these engines are about carbon buildup.
Old 04-25-2012, 06:29 PM
RaiderNick
RaiderNick's Avatar
Well, sainthinds, my mechanic agrees with you. He'll be cleaning the throttle body tomorrow. I'll let you know if this turns out to be the solution.
Quick Reply: Vibration at idle, in gear
