[Z06] Clutch pedal spring popped out
Old 01-16-2013, 01:14 AM
hxrly
hxrly's Avatar
Default Clutch pedal spring popped out
This morning while driving to work I felt like a spring popped out of the clutch pedal. Started feeling with my left foot under the pedals for any foreign object without luck. The clutch still worked okay, so I figured it was nothing serious.
So once I got to the house I gave it a quick look and I found a spring similar to this laying on the floor:
Didn't have time to take a good look so left the car parked in the garage and I'm now on 24h duty wondering how hard this is going to be to put back on tomorrow.
2002 Z06 with ~26k on the clock.
Thanks for any help!
Old 01-16-2013, 09:24 AM
Kmcoldcars
Kmcoldcars's Avatar
Your spring is broken. I had the same thing happen on mine. The car drove fine without the spring. They cost about $ 10.00 new and take about 1/2 hour or less to install, as it is in a bit of a difficult place to reach, under the dash near the top of the clutch pedal.
Mine was a 2002 Z06 with about the same miles on it.
Old 01-16-2013, 09:32 AM
bumble-z
bumble-z's Avatar
hxrly,
Here is a write up in regards to leaving the spring removed or not.
http://forums.corvetteforum.com/c5-t...rn-spring.html
See post # 11
Below that post is how to reinstall the spring.
See post # 12
Here is a close up of the return spring GM part #12555205.
If you decide to re-install a spring, make sure that the two white bushings (shown in pic) are in place & not broken or cracked.
Old 01-16-2013, 01:43 PM
hxrly
hxrly's Avatar
Thank you both, very helpful. It is indeed broken, so I will be stoping by the dealership to get a new one.
Old 03-04-2013, 09:48 PM
texmark
texmark's Avatar
I have an '07 Z06 and it must have a similar (but may not be identical) spring. I found (half?) of this broken spring on the floor under the clutch pedal tonight. The first thing I did was search the corvette forum to learn what it was. Thanks, guys! Since I lost my left hand and wrist a few years ago, I no longer perform mechanical repairs on my cars, so, would anyone have an idea what a dealer would charge for this repair?
Old 03-05-2013, 12:34 AM
Kmcoldcars
Kmcoldcars's Avatar
Ask a dealer. Then remember that for a C5 the spring costs about 10.00 and takes less than 1/2 hour to install, the first time one does it.
Go to your regional forum and see if any of the Corvette owners would do it for you.
Old 04-06-2013, 05:43 PM
oded
8th Gear
oded's Avatar
Default Clutch spring c6
Ordered the spring on line for 12 bucks and took 10 minutes to replace
9 min to get in position and one minute to replace
Dealer quoted $300 .
Old 04-07-2013, 08:18 AM
fxdl
fxdl's Avatar
mine broke several years ago while i was driving. at least 25k miles ago and i've never replaced it. no issues. the car now has 70k on it with original clutch. i'd let it go.
Old 04-07-2013, 08:31 AM
MY03C5Z
MY03C5Z's Avatar
I removed mine, less pedal pressure needed for quicker shifts.
Old 04-07-2013, 05:45 PM
ZeeOSix
ZeeOSix's Avatar
WT? ! ...
Old 04-07-2013, 07:11 PM
stevedun
stevedun's Avatar
Cruise-In 8-9-10-12 Veteran
I would steer clear of that dealership and tell them I was going to make sure everyone else I know did too.
Old 04-07-2013, 07:40 PM
fisher auto
fisher auto's Avatar
Yea, Mine was broken on a car I'm building put a monster stage 3 in it. This thing def. doesn't need it (the spring), should be fine without it!.....
Old 04-08-2013, 05:33 PM
ZeeOSix
ZeeOSix's Avatar
Can't recall where I read it (maybe on this board), but there was a specific reason for the clutch pedal spring ... a purpose that wasn't evident to most people. Maybe someone else recalls the details. That's why I decided to put a new one in when mine snapped.
Old 04-08-2013, 07:45 PM
jmc12
jmc12's Avatar
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17
See post #11
Old 04-08-2013, 08:46 PM
ZeeOSix
ZeeOSix's Avatar
Originally Posted by jmc12
Yes ... that's the info. Thanks JMC.
Old 04-08-2013, 10:20 PM
fisher auto
Just read it and makes total sense!
Old 04-09-2013, 02:26 PM
zeevette
zeevette's Avatar
I wonder if this only applies to GM slaves? I've got a Tick MC, and no spring. Works fine with my RPS twin, but it's the most abrupt clutch engagement I've ever driven.
To Clutch pedal spring popped out
Old 04-09-2013, 02:55 PM
skyavonee
skyavonee's Avatar
Last I checked, Tick specifically instructs to remove the spring with their unit.
With the stock unit, I don't see any reason to remove the spring, or to not replace it if it breaks.
Old 04-09-2013, 06:57 PM
zeevette
zeevette's Avatar
Cool, Thanks. Mine broke several years ago, and I've never missed it.
Old 08-27-2013, 01:50 PM
OldVet64
OldVet64's Avatar
Default 2001 Z06 clutch spring
Thank You! After some skin fingers & right arm,sore ribs on right side, new clutch spring is in my Z06.
Quick Reply: [Z06] Clutch pedal spring popped out
