***This week's specials at Radioflyer Innovations***
Old 01-07-2013, 10:16 AM
TheRadioFlyer
Supporting Vendor
TheRadioFlyer's Avatar
Default ***This week's specials at Radioflyer Innovations***
This week at Radioflyer innovations, upgrade your C5's lighting with some of our amazing products:
Bi-xenon ACA headlights:
The Pinnacle of Headlight solutions for the C5 while still retaining that factory look during the day. At night you'll benefit from 3 times the light output and significantly improved distance and width of view. The included Hi-4 harness and Bi-xenon mechanism provides instant high beams that outperform any other headlight setup (including dedicated HID high beam bulbs) Not even C6 corvettes get this much light. This system is plug and play, bolt on with no permanent modifications required. It can be installed by the DIY mechanic with common tools in about 1-2 hours.
Normally $675....this week just $625!
http://www.shop.radioflyerinnovation...lights-015.htm
Now available with Angel Eye option for just $25 more!
Halo modified tail lights:
The #1 choice for C5 corvette owners for several years. With the "Radioflyer Halo modification", this will bring your corvette into the 21st century. Plug and play installation with no hyper flash harness required. Tinting available as well.
Normally $265, with week just $230 (Halo mod and tinting extra)
http://www.shop.radioflyerinnovation...Lights-011.htm
Hyper flash harness:
If you want to run LED turn signals, you have 2 choices: live with the rapid flashing turn signals or wire in a pair of large resistors that will get VERY hot and possibly melt into wires or plastic panels....neither of which are very appealing options. But now there's a simple solution. With the hyperflash bypass harness, you can simply plug this in under the driver's dash and goodbye-hyperflash. A simple fix to a pain of a problem.
Normally $65, this week just $50
http://www.shop.radioflyerinnovation...arness-027.htm
Adjure reverse lights:
If you want to see at night in reverse, the first step is to get rid of that old factory reverse light housing and replace it with Adjure's Diamond-style clear housing. Want more light? Upgrade to Radioflyer's 20w LED reverse lights. With 200 lumens more light output than your factory headlights, you might decide driving backwards is your thing.
Normally $120, this week just $90 (upgrade to 20w LED reverse lights for $100 more)
http://www.shop.radioflyerinnovation...rvette-013.htm
Hi-4 harness:
Can't sell your significant on that a set of Bi-xenon headlights? No worries, you can get the Radioflyer Hi-4 harness for less than the price of a tank of gas. This effectively doubles your headlight output by allowing the low beams to remain on when you use your high beams. Installation is a piece of cake and can be completed in 5 minutes with no permanent modifications required. Best of all, when you do finally get the "okay" to get the upgraded headlights, you can get your $25 back for already having the Hi-4 harness installed!
This week just $20
http://www.shop.radioflyerinnovation...arness-003.htm
Seat spacers:
C5s with power seats are plagued with an annoying sliding seat that comes from the breakdown of rubber spacers inside the tracks. Every time you brake or accelerate, your seat will slide back or forward. Radioflyer Innovations has the solution with set of custom designed frictionless polyethylene spacer CNC cut to the exact specifications of your seat rails. In just a couple of hours, your seat will once again be rock solid!
This week just $20
http://www.shop.radioflyerinnovation...pacers-006.htm
Old 01-08-2013, 09:44 AM
TheRadioFlyer
Supporting Vendor
ttt
Old 01-09-2013, 09:31 AM
TheRadioFlyer
Supporting Vendor
morning bump
Old 01-10-2013, 11:11 AM
TheRadioFlyer
Supporting Vendor
ttt
Old 01-11-2013, 01:01 PM
AntonioZ06
AntonioZ06's Avatar
2 questions? How long is the wait time for tails with halo mod? Does the 230 include shipping? Going to NJ... might put my order in tonight
Old 01-11-2013, 05:36 PM
TheRadioFlyer
Supporting Vendor
Wait on the tail lights is about 1 week.
Price does not include shipping.
Old 01-12-2013, 08:40 AM
TheRadioFlyer
Supporting Vendor
morning bump
Old 01-12-2013, 12:00 PM
Brit dex
Brit dex's Avatar
Hi Mate
longtime no speak!
last year got a set of LED fronts audi style running lights and Halo rears from you.. which I love!
considering the fronts now with Halo's, what sort of shipping cost to UK?
Old 01-12-2013, 02:31 PM
TheRadioFlyer
Supporting Vendor
Originally Posted by Brit dex
Hi Mate
longtime no speak!
Shipping is calculated by your location upon checkout. Should be in the $50USD range to get them across the pond.
To ***This week's specials at Radioflyer Innovations***
Quick Reply: ***This week's specials at Radioflyer Innovations***
