[Z06] 2004 Z06 leaks
2004 Z06 leaks
Rained here the last few days and I have realized that my car leaks. The driver's side floor board is wet, really wet. Are there any typical places these cars leak? I am afraid this is going to be really difficult to find.
udders....
pull the wheel and then the black wheel well....check the udders...they get clogged with dirt leaves etc....causes wet floor boards
pics
http://forums.corvetteforum.com/c5-g...lure-pics.html
pics
window
I had this problem on both z06's ive had. It was my window seal. The water was leaking down from the pillar down to the footwell adn soaking floor (like flood).
Unfortunately, expensive. to properly fix need to buy new plastic, new metal rail with sealant on it. I bought new window seal for good measure.
The sealant between the plastic and metal retainer on the window cracks probably from heat and cold adn leaks. Can also make headliner wet but not always.
Take off all the paneling for sills and see if you can see water spot from drip down by footwell. Mine had it, but after it rains you can open it and also take a look
Hope this helps cause it bugged the **** out of me. Had to reupholster headliner cause the water ruined it
