my new years resolution is lsx 454
i built this motor from a bare block.has lsa /ls3 heads.12.5 to1 compression.scat crank,eagle rods,wiesco pistons.should run mid 9s on a 200 hit.we will find out shortly.lol
Received 19,293 Likes
'20-'21-'22-'23-'24
Sweet - good luck getting it in the car.
ok boys and girls,lsx in planted in my vette.i got some pics,so if you are gunna install a lsx block in your c 5 there are a few things,you have to modify.a/c braket.pass side motor mount braket.and altinator bracket.here we go.
It's in "Albums", not the garage.
Went in the top with it eh. Is that common with Vettes (I don't know). My experience with F-Body engine jobs is that you lift the car off instead of pulling the motor up. Thought Vettes might be easier the same way.
Look'n good! Mucho fun on the way there.
4th gen f-body out the top? Cause, that's a tight squeeze. Much easier out the bottom on them. Looks like there's a lot more room to do one that way on the C5 Vette.
