Headlamps won't retract
Been away for awhile,but could use some help.Was driving in the rain this A.M.,turned the headlamps on.Got to my destination,turned the lights off,but the headlamps did not retract.Vette is a 2004 zo6,the Z16.When I arrived home,I checked the fuses,ok.I manually retracted the lights,turned the lights back on.They popped right up,but still will not retract when turned off.AQnybody have this problem,or have the answer?
Are they HID and are you sure you don't have a burnt out bulb?
You could have a faulty Headlamp actuator control module or a bad switch on the steering column. You could also have a bad ground for the headlamp actuator control module.
Cruising
I think the battery needs to have a certain level of charge for them to work.
Just my experience.
Phil
It's been said before but this happens most often due to low current draw in the headlight actuator/module assembly. Pretty common with HIDs or with burnt out bulbs.
The best way to test it is to turn on your brights before you turn off the headlights.
If that doesn't work it is either your actuator assembly or switch stalk (as blacksedan87 said).
headlights won't retract
I had a burnt out front turn signal bulb and after consulting the forum, I tried removal by turning on the headlights and removal of the shroud. After breaking the bulb and slicing my thumb open, I tried the other method of getting the car elevated and going through the access panel. It seems that if under dash fuse #6 for the parking lamps is blown the headlights won't retract.
