Corvette Forum
Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 General
Register Forgot Password?
Register Vendors Buy a Vette Albums Search Today's Posts Mark Forums Read FAQ TSB & RecallsGarage
Search
C5 General
General C5 Corvette Discussion not covered in Tech Sponsored by
Bud's Chevy
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 12-19-2012, 05:54 PM   #1
thecapo
CF Senior Member
thecapo's Avatar
Default My engine has arrived - RHS 450cid & AllPro Heads
Special thanks to Chad at Golen Racing Engines for all of your detail work and extra time spent on the dyno testing several cam grinds. Also want to thank Richard over at West Coast Cylinder Heads for taking the time to review the dyno numbers for each of the four cams tested. This really helped me in the final cam selection and I am pretty sure this cam choice will meet my needs - mainly shaking the fillings out of my teeth at idle.
Once engine is installed and tuned - Idle video will follow along with Chassis Dyno Results - goal is 600hp to the tire.
Click the image to open in full size.
RHS Block 450CID
• Callies Dragon Slayer 4.165" x 4.125"
• Callies HD I-Beam Rods
• Diamond Pistons 11.5:1 with lateral gas ports, ceramic top & moly skirts
• All Pro Heads - 12degree, 277cc, Victory - titanium 2.25" in, stainless 1.615" ex, Manley 1.350" dual w/Viton valve seals, CHE Precision rockers
• Comp Cam LSR 247in, 263ex, 107lsa 660"
• Comp Retro-Fit Link Bar
• FAST LSXR 102
• Nick Williams 102 - black anodized
• Siemens-Deka 80lb injectors (high impedance)
• Halltech Killer Bee II
• ATI Super 10% Underdrive
• 17/8” Kooks w/ 3” center
Dyno Video
https://www.youtube.com/watch?v=YB2m...ature=youtu.be
Results
680hp at 6,550rpm
602tq at 5,600rpm
Exhaust
3” Axle Back B&B C5 Fusion exhaust - a few pictures comparing my old Corsa Indy to the new B&B
Drivetrain/Suspension
• MGW Shifter
• RPS LSX BC2 Twin Disk Carbon
• RPM TR6060 Level VI conversion
• RPM C6 Z06 Stage 4 conversion with Quaife
• PFADT C6 Transmission Mounts
• PFADT FeatherLight Coil Overs
Fluids
Valvoline 75W90 - rear end
Royal Purple Syncromax - transmission
Royal Purple XPR 5W30 - engine
Other Mods
Just finished installing my C6 splash guards front and back. Mini Tubbing next and will be running 345's out back on 19x13 CCW's.
thecapo is offline   Reply With Quote
Old 12-19-2012, 06:07 PM   #2
dankhts
CF Senior Member
dankhts's Avatar
Engine ****!
Looks like an awesome build!
dankhts is offline   Reply With Quote
Old 12-19-2012, 06:09 PM   #3
CF Senior Member
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13
Very, very nice. Your car ought to really be a blast to drive once all those parts are installed.
Vetteman Jack is offline   Reply With Quote
Old 12-19-2012, 06:13 PM   #4
LoneStarFRC
CF Senior Member
St. Jude Donor '08-'09-'10-'11-'12-'13
LoneStarFRC's Avatar
Nice!
Who's offset differential mounts are you using? They look like OEM C6 pieces. Have they been modified to make the studs offset?
LoneStarFRC is offline   Reply With Quote
Old 12-19-2012, 06:19 PM   #5
WKMCD
CF Senior Member
WKMCD's Avatar
Great build. Richard is a great guy with some great products. He was involved in the multiple iterations of my build.
You should be over 600RW easily. My little 427 was at 656hp on the Superflo engine dyno and does 577RWHP with 530RWT. I run Richards Stage 3 L92/LS3 heads with a little 234-242 cam and it's so mild my wife could drive it.
Question for you...Does Richard like the CHE rockers with the .660 lift? I really need to get the YT's out of my car. I've already broken a few from two different sets.
Congrats again.
Adding the engine dyno graph.. You should be able to figure out pretty close to where your rear wheel numbers will end up.
__________________
"The Gentleman's Cruiser"
Super Mild VA Speed 427 - 577RWHP/530RWT WCCH Stage 3 LS3 heads and a little baby cam Trans/Diff by RKT56.com, - PFADT CO's and Bars - Tuned by Ed Hutchings
Build Thread: http://ls1tech.com/forums/generation...b-c-d-e-f.html
WKMCD is offline   Reply With Quote
Old 12-19-2012, 06:48 PM   #6
maxx2200
CF Senior Member
Support Corvetteforum!
maxx2200's Avatar
maxx2200 is online now   Reply With Quote
Old 12-19-2012, 07:01 PM   #7
ssrallyred
CF Senior Member
ssrallyred's Avatar
Quote:
Originally Posted by dankhts View Post
Engine ****!
ssrallyred is offline   Reply With Quote
Old 12-19-2012, 08:06 PM   #8
momo20
CF Senior Member
momo20's Avatar
Send a message via MSN to momo20 Send a message via Yahoo to momo20
wow amazing setup..can't wait to hear vids of that beast..
momo20 is offline   Reply With Quote
Old 12-19-2012, 08:12 PM   #9
Paul 75 L82
CF Senior Member
Paul 75 L82's Avatar
Send a message via AIM to Paul 75 L82
Very impressive.
__________________
2002 Electron Blue Z06, TSP 228R@112 LSA. PRC Springs, LS2 Chain, Ported LS6 Oil Pump, Halltech Venom, Borla Stingers & X, JBA Headers, C6 Shifter, C6Z06 Shocks, Kenwood Sound, C6 Z06 Deep Dish wheels & Michelin PS2's.
Paul 75 L82 is offline   Reply With Quote
Old 12-19-2012, 08:24 PM   #10
TheVettePirate
CF Senior Member
TheVettePirate's Avatar
Engine Porn
TheVettePirate is offline   Reply With Quote
Old 12-19-2012, 08:45 PM   #11
Spreader
Junior Member
Looks great! Did you consider higher compression and E85/E98? Just curious, not being critical.
My 440c.i. puts 540hp/520tq to the wheels on 11.7:1 and 91. I've been told it's a stingy dyno too, but that doesn't really matter much. I bought my car already built otherwise I would have gone 13.5:1 and E85 for that extra ~5% to the ground.
Spreader is offline   Reply With Quote
Old 12-19-2012, 08:52 PM   #12
El original
CF Senior Member
El original's Avatar
YIKES!!! Suck me through the intake and blow me out the exhaust. How much $$?
El original is offline   Reply With Quote
Old 12-19-2012, 08:55 PM   #13
Abnmarine
CF Senior Member
Abnmarine's Avatar
Awesome build. Look forward to hearing the results.
Abnmarine is offline   Reply With Quote
Old 12-19-2012, 09:09 PM   #14
7LitreC5
CF Senior Member
7LitreC5's Avatar
That looks great! My 427 is coming out in mid Jan and is being sent to Golen for a rebuild and some enhancements. I am glad to hear that you had a positive experience. Mine will be run in on their dyno before it is shipped back.
7LitreC5 is offline   Reply With Quote
Old 12-19-2012, 09:27 PM   #15
VETTEV
CF Senior Member
VETTEV's Avatar
Sweet!
VETTEV is offline   Reply With Quote
Old 12-19-2012, 09:30 PM   #16
thecapo
CF Senior Member
thecapo's Avatar
Congrats again.
Thanks for the dyno graph that does give me a benchmark. Richard definitely likes the CHE rocker setup - one less thing to go wrong.
Old 12-19-2012, 09:33 PM   #17
thecapo
CF Senior Member
thecapo's Avatar
I would have loved to went to a 13:5CR, but unfortunately no E85 at the pump in Canada.
Old 12-19-2012, 09:43 PM   #18
Blitzkrieg
CF Senior Member
Blitzkrieg's Avatar
Quote:
Just the Short Block is right around $9,000!
Blitzkrieg is online now   Reply With Quote
Old 12-19-2012, 09:53 PM   #19
JaxEagle
CF Senior Member
JaxEagle's Avatar
Quote:
A blast? A scary blast!! Wow I love this build! Damn damn damn - sweeeeet!!
JaxEagle is offline   Reply With Quote
Old 12-19-2012, 10:06 PM   #20
James2002z06
CF Senior Member
James2002z06's Avatar
Are you telling us that NA engine has 520 RWHP
James2002z06 is offline   Reply With Quote
Reload this Page My engine has arrived - RHS 450cid & AllPro Heads
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Emails & Password Backup
