My engine has arrived - RHS 450cid & AllPro Heads
Received 1,762 Likes
ttt
To the OP here very nice build for sure love the RHS block. I cant wait until I get the RHS little 427 into the car and see what it does in the rollers.. Also that can on those numbers that is going to be one hel1 of a cam for sure.Robert
Man, thats a very nice looking build. Ill be giving them a call when I'm ready.
It is a stock C6 cradle only some slight modifications. RPM did the install at thier shop in Indy. Rodney and Jeremy are great guys to work to with and can answer any questions you may have.
Chad is great guy to work with and extremely knowledgable with over 20 years in the business. I called several shops before deciding to go with Golens. He is very meticulous, documents all the details, takes the time to talk with you, and goes the extra mile. Definitely one of benefits of dealing directly with the owner - you will not be disappointed.
#35
#37
Thanks. I needed to hear that. My current build never was right. It has always burned more oil than it should so it is finally time to take care of that. I really want it to be right this time and it sounds like I have no worries going with Golen.
#40
Regardless of what some people will tell you. It is very possible to have a stroker not burn any oil...mine doesn't. It's Darton Sleeves LS2 block with a 4.125 bore and a 4 inch crank.
