my 2002 zo6 eats oil
Old 11-19-2012, 05:00 PM
myslvlt4
myslvlt4's Avatar
Default my 2002 zo6 eats oil
I have an 02 cammed zo6. It has only 18500 miles on it and runs perfect. It doesnt have any oil leaks, but it burns about 3/4 of a quart every 600 to 800 miles. Is this normal for a cammed c5? Does anyone else have this issue? Just want to know if i should be concerned. Thank you.
Old 11-19-2012, 05:50 PM
calivette805
calivette805's Avatar
some say its normal . pull your tb out and stick your hand in your manifold see if theres any oil . my cammed ls1 would get alot of oil on there threw on a catch can
Old 11-19-2012, 08:07 PM
Paul 75 L82
Paul 75 L82's Avatar
Did you install new valve seals when the cam was installed?
Old 11-20-2012, 12:07 PM
myslvlt4
myslvlt4's Avatar
I bought mine three years ago, with only 7 thousand miles already cammed and all modifications done. I know the springs are harden with the cam. And car has no leaks, after I got the rear main seal leak taken care of. And I also put on a catch can. But it still eats oil. Thanks for your help.
Old 11-21-2012, 02:16 AM
Fixed
Fixed's Avatar
It is more normal if you drive hard with LS cars. They tend to throw oil through the PCV at high RPM. My car uses a bit of oil as well.
Its a Chevy. You know they are running good when they use/leak oil!
Old 11-21-2012, 07:56 AM
Paul 75 L82
Commandment #1
Old 11-21-2012, 09:25 AM
1BADAZ50TH
1BADAZ50TH's Avatar
This is a known concern with the LS6. GM was replacing the top compression and oil rings to correct on vehicles that would see high rpm and were using oil under warranty. Some say the condition is that the cylinders are not perfectly round (have flat spots) that cause blowby feeding the PCV system. Catch can can help but you still will go through oil, just not as much through the throttlebody. I thought I had this problem after installing 243 heads but found 4 bad valve seals. Watch your oil level.
Old 11-21-2012, 10:12 AM
bstone1989
bstone1989's Avatar
I drive mine pretty hard and I have to had about 3-4 quarts in between oil changes
Old 11-23-2012, 03:59 PM
myslvlt4
myslvlt4's Avatar
Thanks everyone... I feel better knowing I am not the only one and to know that its common with LS motors. I think i have to add about 3 quarts also. I hardly drive cause it just sits super clean in garage but when i drive it, I drive it hard and wind it out alot. Cant help it since its a treat to drive. Thanks again everyone.
Old 11-23-2012, 04:48 PM
HG
HG's Avatar
Read this http://www.c5registry.com/2k2z06/page5.htm
Old 11-23-2012, 09:50 PM
SPEED750
SPEED750's Avatar
I find that hard to believe as normal. The motor holds 6.4 quarts and your putting in 3 to 4 quarts between oil changes. Why even change the oil ? just get a K&N oil filter and within 10,000 miles you have all new oil anyway. Just say'n !
Old 11-23-2012, 09:54 PM
_r2h
_r2h's Avatar
This is great logic!
Old 11-23-2012, 10:30 PM
racebum
racebum's Avatar
do a vacuum test, takes a few seconds, look for any flutter in the gauge. if none proceed to a leakdown test. with that kind of oil consumption you very well could have a cylinder with cracked ringlands and or rings.
both these tests need to be done, report back with the results.
if you have flutter in the vacuum reading by the way that's more or less a confirmation of low compression in a cylinder.
too much timing in the tune could have done it. many things.
do those two tests and let us know the results
if both tests check....which would be unusual using that much it would be high time to improve the pcv system
using a quart every 2000 miles isn't that uncommon. a quart every 500-800 will take out exhaust valves eventually if left untreated. the carbon build up will cake on, prevent cooling and eventually the valve frags.
Old 11-24-2012, 04:18 PM
CeeRow
CeeRow's Avatar
I lose about 1-1.5 quarts after putting in 7 quarts. I normally change it after 5K miles driven fairly hard. Very normal for our cars.
To my 2002 zo6 eats oil
Quick Reply: my 2002 zo6 eats oil
