stock shifter height
How high does the stock shifter stick up from the center console? I have a feeling the previous owner of my c5 z06 installed a short throw. To the highest point of my stock shift **** in nuetral it's 5 1/4" Can someone measure their stock one and let me know? It just seems way too stiff to be stock. Thanks!
Oh it's crazy stiff. I used to own a 2004 CTS-V and expected the z06 to be similar. Not even close. In neutral it takes some strength to flop it from side to side and it looked a lot shorter than I expected.
1 Post
Do the anti-venom mod 1st. Costs about $1 and makes a big difference in the stiffness. Here's the write up on how to do it:
http://www.toquez06.com/avm.html
stock height is about 5 and 3/4 inches. Check out this writeup I did back in spring when I installed my MGW, I included pics of stock vs. short throw.
http://forums.corvetteforum.com/c5-g...ifference.html
I would try the anti-venom first. Even with the MGW, which I have, it is smoother and more exact, but the shorter shifter does decrease leverage, requiring more effort for making shifts. I ended up getting the longer shifter with my MGW. I get the preciseness for road racing with the comfort for dd. Good thing about shifters, is they are not hard to change, and you can get good deals on used ones to try until you find the one you like. I have had stock shifter, C6 shifter, B&M shifter and MGW. Good luck with choice.
The stock shifter does not. In screws down and then has a demon key to hold it straight. If you look at the RSD shifter in the pic, you can see where it actually has a bolt hole at the bottom where the shifter is bolted to the shaft. It is actually a C6 shifter that has been shortened and threaded for C5 ****. If you can post of pic of yours, someone can identify it.
