BO441 code ?
1 Post
It's a little box with cheap plastic gears in it. What is does is open the doors in the HVAC system to let in either the heat or the cold.. In my case it didn't let the heat in so I had no heat on my side and my wife was warm on her side... I replaced mine this spring.. took me about 3-4 hrs with breaks and following the replacement guide listed in the tech sticky.
Thanks for the info.
Left Actuator Out of Range
Thanks.
