Aged C5
Banned Scam/Spammer
Received 1,319 Likes
Dothan Alabama is a small place on Earth.
For your exact request I’d say, nobody.
That being said, what issue are you having?
Might actually offer an option you can check into yourself saving money.
CorvetteBrent (09-27-2020)
St. Jude Donor '17-‘18-'19-'20-'21-'22-'23-'24
Welcome to the Forum, and congratulations on your C5!
You may want to post your question in the Southeast section at https://www.corvetteforum.com/forums/southeast-42/. This will put your question in front of members in your area.
Also check to see if there are any Corvette meets taking place around you. You may find an owner there with good C5 electrical experience who can assist you.
~Josh provided great insight - more info on the issue(s) you are having may allow someone on the Forum help you check the issue yourself. Lot of great members on the Forum with tons of C5 experience and info.
Best wishes with an easy and inexpensive fix!
Thank you all for your response. I'm guilty of being wordy so I'll try and be specific. After a heavy rain I found a small puddle on the driver side floor. However, the problem I'm asking about concerns the wipers. The intermittent function no longer works although slow and fast do. When I then turn the wipers off they may or may not stop. I have resorted to pulling the fuse and driving only when good weather is expected. I do small bolt-on jobs but electrical intimidates me.
Banned Scam/Spammer
^The right stalk needs to be replaced. It’s common for the wiper control to fail in that multifunction stalk.
Autozone carries an aftermarket version cheaper than factory.
I worked at a corvette-only repair shop and we kept several in stock at any time.
The issue of water on the floorboard is unrelated. That is an issue aside.
The following 2 users liked this post by ~Josh:
JimHarris4 (10-02-2020),
jjc508520 (10-06-2020)
With respect to the H2O problem, check the "udders", under the cowl area, for debris that's clogging them.
The following 2 users liked this post by leadfoot4:
silverja (10-04-2020)
