Base C5 GM Susp Upgrade - C6 Z51 Sway Bars - C6 Z06 Shocks - www.gmpartshouse.com
Premium Supporting Vendor
2012 C6 Z51 Sway Bars!
Greetings Friends,
We have the Z51 sway bars kit with the Genuine GM bushings for $208.17.
The reason people use these bars most on the C5’s and the C6’s is because unless you’re running 335 width tires in the rear, these are the way to go. These bars don’t cause the vehicle to ride “stiffer” per se. They are mostly for the cornering ability.
You know that feeling when you’re going into the turn and the car leans pretty heavily? These bars are meant to make the vehicle feel flatter in the turns and corner much better in the turns. Another advantage is the handling when you’re coming out of the turn. When you come out of the turns you will not be fighting the wheel as much as you would with the stock bars. These bars, since they’re thicker, make it easier all the way through the turns.
Below are the specifications and comparisons of the C6 Z51 sway bars compared to other Corvette suspension packages.
Corvette Sway Bar Specifications
Suspension Front (mm) Rear(mm)
C5 base 23.0 19.1
C5Z51 (97-99) 25.4 21.7
C5Z51 (00-04) 28.6 23.6
C5Z06 30.0 23.6
C6 base 25.5 17.5
C6Z51 31.0 25.4
C6Z06 31.0 28.0
We offer these sway bars with the 2012 C6 Z06 shocks. Also, whether it is a C5 or C6, coupled with the 2012 C6 Z06 shocks it makes a total different handling package. This package speaks for itself as we have many testimonials from many customers from whom we sold these to here on the forum!
To order, please call 484-949-2099 or go to www.gmpartshouse.com and use part number c6z51bars and be sure to select Chevrolet make.
Thanks. Gene.
||--Genuine GM C6Z51 Sway Bar Kit--||
25919502 – Front stabilizer bar
10339124 – Rear stabilizer bar
10387838 – Front stabilizer bar bushings (2)
15241135 – Rear stabilizer bar bushings (2)
Complete kit front and rear is $208.17
Use part number c6z51bars on our website under Chevrolet make.
2012 C6 Z06 Shocks!
We sell the 2012 C6 Z06 shocks for $254.60. Many C5 customers ask us why we don’t recommend the 2004 shocks over the 2012. Many people also say that the C6 shocks are only developed for the C6. If you look at all of the basic suspension components between the C5 and C6, they are very much the same. The reason we don’t recommend the 2004 Z06 shocks over the 2012 C6 Z06 shocks is simply because of the price and customer feedback. We have many customers who have tried both sets of shocks and cannot tell the difference between the two, so why not purchase the lesser expensive set!
For the C5, not C5 Z06, we also recommend the C6 Z51 sway bar kit. The C6 Z51 sway bar kit coupled with the 2012 C6 Z06 shocks is our most popular suspension and handling upgrade for the C5.
To order, please call 484-949-2099 or go to www.gmpartshouse.com and use part number c6z06shocks and be sure to select Chevrolet make.
Thanks. Gene.
||--Genuine GM 2012 C6 Z06 Shocks--||
10313647 – Z06 Front Shocks
25819268 – Z06 Rear Shocks
Both sets of front and rear shocks (4) $254.60 total.
For the shocks on our website, use part number c6z06shocks under Chevrolet make.
The C6 Z06 shocks will work on stock C5’s and C6’s without modification.
We no longer offer PFADT poly bushings with the sway bar kit!
Greetings Friends,
C5 base 23.0 19.1
C5Z06 30.0 23.6
C6 base 25.5 17.5
C6Z51 31.0 25.4
C6Z06 31.0 28.0
Thanks. Gene.
2012 C6 Z06 Shocks!
Thanks. Gene.
__________________
Phone: 484-334-8833
Owner of CULTRAG Performance
Shop Our Factory GM Parts Website
Phone: 484-334-8833
Want to buy
I have the 2004 base convertible C5
I understand the best buy will be the C5ZO6 sway bars and the C6Zo6 shocks. Is this correct??
Is there a better price if I buy the 4 shocks and 2 sway bar together??
Thanks, will be waiting
carfix@integra.com.sv
