Z06 Front Screens Functionality?
Received 2,673 Likes
2018 C5 of Year Finalist
I've been reading the various threads about Z06 owners who want to add fog lights and that brings up a design question...
Do the OEM Z06 screens perform a special function for that model and why did GM decide not to originally include Fog Lights for the Z06?
I know the C5 is a bottom breather and I know that the aftermarket Vararam CAI design takes advantage of the OEM fog light housings to route air up and through the intake. Do the Z06 screens provide similar air flow or is the Z06 a pure bottom breather as well?
As mentioned, I understand the engineering of the Vararam unit, however the OEM Z06 air intake is similar to the stock air intake correct?
The screens themselves don't provide any enhancement, especially with the foglight shrouds in place - in fact, I once calculated the percent of area lost to the blockage created by the screen itself and it was significant. In other words, if you had a piece of sheet metal the equivalent surface area of all the wire the screen contains and placed it in front of the opening, it would block a measurable amount of air flow. So, you could argue the screens cause a reduction in air flow.
I have a Vararam setup on one of my C5's and I left the screens in place to guard against larger debris getting sucked into the ram tunnels and up to the MAF. They have worked perfectly in that regard as the filter in front of the MAF is still free of significant debris so the tradeoff is worth it.
On the other hand, removing the screens and the shrouds behind them could have a positive effect on underhood temps. I have logged MAF temps with the screens and foglight shrouds in place and a Blackwing intake installed and then with the Varamam in place on the same car and temps were up to 30 deg. F lower on the Vararam setup, depending on the ambient temp. The biggest temp delta between ambient and MAF was on hot summer days.
Received 19,228 Likes
'20-'21-'22-'23-'24
Can all C5s benefit from this extra airflow if the OEM plastic fog light shrouds are removed? How does the additional air route up into the filter area? By looking underneath where the air flows up through the lower radiator shroud, how does the air coming in from the fog light area, through the Z06 screens route into the intake?
Take the fog light shrouds off and you have an open path to where the air intake sits. Therefore in addition to scooping up air from under the car, there would be air coming in from the front of the fascia too. This of course would also allow extra dust and water to enter into that area. But not sure that any water coming in from there would be detrimental or not - just not sure how much would actually come in contact with the air intake. And with the exception of not having the fog light shrouds in place and having a larger opening on the air intake for the air to enter, yes, the OEM Z06 air intake is similar to the coupe/vert air intake.
I'm planning on adding a Callaway Honker CAI and I have a set of unused, never installed open fog light shrouds (picture below) given to me by a friend who taded into a C6 and I'm considering installing them when I install the Honker.
St. Jude Donor '09, '13, '15
This is great information that helps me understand the real purpose of the screens because otherwise, as a "styling" mod, I think they detract aesthetically from the overall design of the front fascia.
AKA "The CLOWN"
I removed the plastic shrouds around the fog lights and did the front plate mod. I removed the front air dam and I get plenty of fresh air into the motor and intercooler. Car has never seen temps higher than 210 degrees on the hottest summer days.
This is my setup. Obviuously its not a VR,but a Blackwing. I opened up the radiator shroud to let fresh air in and to get the most out of the Blackwing. Lower engine temps and cooler intake air means better running engine and more power.(These are early pictures. i have a mesh screen that I attached to the shroud opening.)The air temps rarely rise over the 200 degree mark. Its all good.
Location: This is not a Song, It's an Outburst: Or, The Establishment Blues; Sixto Diaz Rodriguez
I have a z06 with the screens over the fog lights, i recently purchased another front plate cover to modify and left my stock one normal.
I have significant more airflow into the engine bay, my temps are really low. Since i did the plate mod and thermostat.
The dust IS NOT A BIG DEAL, i blow out the entire engine compartment with a compressor and hose.
No water enters anywhere near theSLP filter
Thanks. I wasn't sure whether or not the air coming in through the opened fog light shrouds had the same or different path into the air intake than the air that comes up through the bottom.
I cut out a large 1 inch by 5 inch area into each plastic shroud and installed Z06 screens. The underhood and intake air temperature have dropped significantly. So yes, it is worth doing this mod to all C5's even if you have a stock intake. Dust and water is really not an issue. I haven't noticed any increase in dust under the hood and the water will not make it up to the filter.
