LMC5 Column Lock Installed, Now permanently locked
Well just got done with installing the Compliance Parts LMC5 to prevent my column from locking in the future, followed the instructions to a T and now my steering wheel is locked.
After completing the installation, I inserted the key, turned to the on position, didn't get any DIC error messages. Ok cool, started it, no error messages. Started it a few more times, no error messages. Then I wiggled the wheel after I had removed the key then it locked. I figured no biggie, I'll insert the key again and it will unlock, not so much!
All though the install the steering wheel was not locked, it locked up after I took the key out after the installation. Any ideas? Just left Rick at Compliance Parts a message, figure he'll get back to me in the morning. Any help in the mean time would be appreciated!
I've read the it could be possible that the CLB and BCM could have gotten out of sync and that pulling fuse 23 will reset the BCM. Any issue with doing so?
You should call them... they can give you way better advice then most of us.
I had issues with there LMC5 module and called them today..
There way nice to talk to and are willing to help out.. (855) 565-8388
Good Luck with the cure
Any harm in just uninstalling the LMC5 then trying again?
Received 19,584 Likes
'20-'21-'22-'23-'24
Good luck to you - hope it is something simple that can be done to get the wheel unlocked and the install successful.
I hope it's something simple as well, everything was working fine after the installation, until I had shut the car off, jiggled the wheel then it became permanently locked. Messing with it last night, I was able to get the wheel to move about an 1/8th of a turn then it locked up again.
Mine worked fine also before the install. You have to use the unlocker to disengage the lock on the wheel and then permanently disconnect the relay that controls the locker motor. Then you install the module. The wheel will always be unlocked.
Thanks for all the info so far!
Received 1,309 Likes
C3 of Year Finalist (stock) 2019
C2 of Year Finalist (stock) 2019
Sounds like you may have missed a step in the procedure to install the LMC5...
Since the column would be locked with NO KEY in the ignition, if you don't take some step to get it unlocked BEFORE you start installing the LMC5, it will be locked when you get it installed as you are experiencing.
As was suggested above, I would call them and talk about the procedure that you need to follow.
If a steering column does what it is intended to do- that is, lock when the key is out and unlock when the key is inserted, then there is no need for the "UNLOCKER" and the LCM5 can be installed and correct the issue. Further, the ONLY time the "UNLOCKER" is needed is if the steering column locked IN ERROR and PRIOR to installing the LMC5.
The wording in the LMC5 instruction sheet says that the UNLOCKER is required if the steering column locks with the key out of the ignition, which to me, sounds like the UNLOCKER is needed even though the steering column is performing as designed?
I'm thinking that now that the column is locked with and without having the key installed, I just need to use an unlocker and I'll be good to go. I was thinking along the lines you are in that if my column lock is working as intended, I wouldn't need the unlocker when installing the LMC5. Now that this issue has come up, it sounds like I do.
Well if it wasn't for bad luck I wouldn't have any luck at all, that is why I have the unlocker, and LMC5 in my trunk. I would've never ending issues if I tried to install it now.
Now before people say Oh sure he is full of crap he could slap the LMC5 in. I've walked into a bank they couldn't take my money I had to go back the next day. I had cataracts when they did my left eye the IV didn't work the Doctor couldn't stop to do a new IV so I watched my eye being taken apart with no drugs. I could go on for days, so unlike the OP I know for me its, don't try to fix what isn't broke.
No update as of yet, I'm at work at the moment so I haven't had a chance to work on this. Looks like Compliance Parts opens in 10 minutes, will give them a call then. Will let everyone know what I find out!
