A Month of Sundays
#61
Location: Should this thoughtful, valuable contribution meet with no acknowledgement or 'thanks' this post----
nice progress...I think his front end has an overbite look that is not as attractive as the C5...agree?
#62
1 Post
I ordered some Lazer Mesh fog light and brake duct inserts that will dress it up a bit
#65
1 Post
Ties into the mods to the rear fascia and side brake duct exits.
I'm adding a few more chrome pieces to the front that will make them tie in better.
Not going for a "mean" look with this car....more of a California Sunshine Cruizer with Bruizer power and cat like handling ;-)
#68
Yeah, Ive seen a bunch do that on the F150 Ford truck headlights, they would paint the inside and it turned out good. I think they would bake the headlight assembly in a regular over at a certain temp and then the assembly would come apart easier when the glue warmed up.
#69
1 Post
thanks bro...that baking thing is a good tip...was Trying to figure out the best way to get them apart without cracking them, because I want to try some interesting things when the new tape lights you see on the newer Land Rovers and stuff
#72
1 Post
Its a subjective thing
regardless of where you land on aesthetic preference, there is no debating the numbers....my car is faster, more agile, and has a lot better quality of construction ;-)
Its in better condition after 126,000 miles and 15 years than his car is after 3,500 miles and 8 years
#75
1 Post
Basically its a lower performing disposable car that costs 10 times more than mine lol
Basically, buying a Ferrari is only about two things...funding a subpar Formula 1 team....and having a flashy well engineered but poorly built ego symble that sits in your garage.
My car is a real driver's car, with higher performance, that can be driven hard everyday for decades.
#77
1 Post
I have not updated this thread in a while!
And since I'm going to take the car in a whole new direction I'd thought I'd revive it.
Am gunna do something a but unique, and convert the car into a lightweight Roadster dedicated track day car.
I am taking the whole car apart and removing every possible bit of weight to try and get it down to 2500-2600 lbs....we'll see if its possible.
Some people dismiss the idea of a vert track day car, but I love going fast with the roof off, and I can get it pretty close to as light as a Z06 I think.
As far as stiffness goes, a cage will stiffen up the vert deficiencies there I think.
I'll post picks as I go along.
I am think of going with a Crower crank and Quartermaster lightweight racing clutch for a lightweight rotating assembly, but need some advice on the most bulletproof valve train, i.e. lifters and all that.
Would like to spend less than $5000 bulletproofing my ls6...any recommendations would be greatly appreciated.
