Help!! I think its over heating
I live in so cal and its been 80-90* and if i turn my ac on in the streets or traffic my temp shoots all the way to 230-240 but once i turn it off it come back down to 220 amd i have a 160* thermosat!!! Oh but i have no problem with the ac on if im driving on freeway with no traffic it stays like at 180 wth is goin on and i no leak or water missing from resevoir !!!
ANY INPUTS ON THIS WILL HELP
ITS A 04 c5 manual tranny with 44k miles
have you cleaned all the crap out from the radiator/condenser area?
start there and get back to us...
Received 2,687 Likes
2018 C5 of Year Finalist
I installed a Callaway Honker CAI as well as the slotted fog light shrouds to help the car breath a little better. As a result of this bottom-feeding design, I also installed a radiator screen to help keep out plastic bags, large leaves, etc.
Even with the added protection, I still remove the screen once a year and pull out any small debris that worked it's way up into radiator area.
St. Jude Donor '06
Those temps sound pretty normal for a/c on and 90* ambient.
A 160* thermostat is no guarantee your engine will run that cool. It's only the temperature at which it is fully open.
Good advice above however to check the radiator and install the screen.
Nick
Nick
Received 2,709 Likes
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16'-'17-‘18-'19-'20-'21-'22-
'23-'24
Make sure that your front lower black air dam is ANGLED correctly to direct air into the radiator. Seen this issue a bunch on friends car's. It is spring loaded and if its bent or the springs fail it will not push air into the radiator.
Toque
Toque
Received 19,439 Likes
'20-'21-'22-'23-'24
Thats exactly how mine looked i just finished cleaning it out now i just need to drive it around and see if it helped but its a bit gloomy today its about 68*lol crazy weather so ill keep u huys updated on this hopefully it helps out thanxx guys
That's is high. My 2000 FRC rarely exceeds 205 in stop and go traffic and with temps in the mid 90's or higher. I have never seen 230. Just flushed radiator and my radiator fins are in good condition.
I had just filled my radiator ond resovoir with new coolant and didnt work but i cleaned out my radiator shroud from top amd bottom worked a bit but havent really trid it in hot weather like the day it hit 235 so im just waiting for it to get hot again
