Cruise,active handling and trac control?
Location: sometimes the lights are shining on me, other times i can barely see minnesota
I'm wondering if anyone has any ideas for me, driving to the dells today and my cruise would disengage on its own after about 3-10 minutes. Also got service active handling soon message and traction control light twice. If I shut car off and restart they would work again for 30 minutes or so.
Does this sound like some kind of vacuum problem or am I way off base thinking old school? Car is a 2001 vert with 63K on it
Allen
Received 19,369 Likes
'20-'21-'22-'23-'24
Will be following this thread.
Cruise Control Problem
Had same problem. Went to a Carburator/Electric Repair Garage and they
came to the same conclusion. Replaced the SWPS at the end of the steering column. Total cost was $215, and the 2004 Vette handled like a new car. Found out some other GM autos and Trucks have this same SWPS. Its been over one year and still handles like new,wish I had done this sooner.
ok got home yesterday, thanks for the tip on turning off traction control allowing cruise to work. that came in handy on the 6 hr drive.
i ran my codes this morning and under 28-tcs i have a c1287 which is steering sensor rate malfunction so it looks like you guys know what you are talking about as always and i will get the steering wheel position sensor replaced. thanks again.
They cost about $65.00 at www.gmpartshouse.com. Takes about 2.5 to 3 hours to replace. Had to replace mine last year on my 04. Be carefull with the airbag and do not turn the wheel once disconnected.
