clay bar cleaning
Received 1,681 Likes
I'd say that the kit would be as good as any of them.
I used it and it worked great. Use a good amount of their Quick Detailer with the clay bar
Meguires clay is very good!
Meguires clay works great and so easy with great results. I wash my vette with dawn, clay bar it, wash it again. I then buff it with porter cable using meguires #26, then wax with meguires #105. Got rid off all the swirl marks and small scatches. Left a finish like new. Check out amazon and auto geek for good prices. Autogeek has great prices and free shipping! My vette is black so I do it allot. If you run out of lube, I use the soapy dawn water in a pinch. Keep the spray bottle in one hand, the clay in the other, and as others have said-do small areas.
One thing not mentioned in this thread that I was told before I did it the first time and it really helped is to wear a surgical rubber glove while claying! Drastically reduces the likelihood of dropping the clay as it sticks very readily to the rubber glove. You can't drop it as you have to peel it off of the glove!!! Saved me a bunch of "OOPSES" the first time.
If you stick to the known brands, you will not have a problem, they all work well - personally have used Meguiars, Mothers, Clay Magic, 3M.
I like the Clay Magic and Mothers, more, that said they all worked well.
Oldtimer
St. Jude Donor '13
I've had good results with the various clay bars available. I've found that if I want to save any clay after using I put it in a baggie spraying the inside of the bag & clay & sealing the bag...
#33
Received 2,688 Likes
2018 C5 of Year Finalist
After reading this thread, what is the secret to "Dawn" dish soap that makes it strip automotive wax? Do you wash with dawn, clay and then wash with Dawn again?
#34
Dawn will strip off the old wax, and that is what I do, but I don't rewash the car afterwards. I may use my waterless wash, but I have not found the need to do a complete rewash.
#35
Oldtimer
I learned about Joy from my optician who uses a 'magic' solution to clean glasses. Just a drop of Joy and some water.
#36
Back when I used to detail mine lovingly, I found the bar didn't seem to work as well with dawn as it did with the detailer liquid. The clay bar will remove all the old wax and polish, so car will have to be polished and waxed afterwards. After clay bar, it is a good time to remove some of the deeper scratches and swirls and there are plenty of diy threads in the Car Care Section. Nothing like removing that last coat of wax and admiring what 12 hours of hard work will do.
#38
I use mostly Adams products so my routine has been (1) wash, (2) clay with detail spray, (3) swirl and haze remover where needed, (4) machine polish, (5) machine wax, (6) buttery wax and (7) brilliant spray glaze.
#39
I use Adams as well, except I use the Americana and not the machine wax. If you do a good wash with the Dawn that should remove the wax. Also the clay will remove any remaining wax.
#40
