Question on new tires
Hi... This might sound like a dumb question but I just bought some new michilen pilot super sport, 305/19/25 in the rear and 275/18/35 in the fronts on my 2002 zo6 which with a head and cam package dyno tuned at 424 rwhp and 406 rwtq, at first still spun tires real good first and second gear with traction control on. Than after driving for a few hundred miles, I am lucky if i get a little spin only shifting into second but no more driving in first punching it and roasting first gear on the street. Do new tires really make that much of a difference? Or does my car need another retune which is a dread.
I know with drag radials after breaking them in does make a big difference but these are just good quality street tires. Also zo6 was running super strong when its was nice and real cool and now it is hot here in texas. Thank you for your help.
Do they get sticky enough to reduce the wheel spin in half or more and get good traction? I am just trying to see if mine lost the power like it did before or is it just good traction. Thanks.
Received 2,385 Likes
C4 of Year Winner (performance mods) 2019
There is a coating on them from the factory, it's to help them come out of the mold easier. It's pretty slick, so once it wears off (~100 miles) the traction will improve dramatically.
The first thing I did after new PS2's was a 4 wheel alignment. Wow, the alignment made all the difference. Shop said it was a track alignment so the tires were flatter on the ground and it really made the difference.
Received 19,687 Likes
'20-'21-'22-'23-'24
Changing the tires should not affect the power output of the engine - but it could affect how the car puts that power down to the ground. Once you get a few miles on the tires, they should get stickier and could be you just hook up much better.
I too just purchased a set of Michelin PSS in 18 and 19. I love how well they handle and the grip is fantastic. I'm running very similar rwhp numbers as you and also have 3.90 gears. I can certainly spin the tires if I lay into it, but I have to try hard to get them to spin.
Michelin has outdone themselves with this tire. For $1600 mounted they are an extreme value.
I wouldn't worry about your car "detuning". It seems to me that your tires are doing their job and putting the power to the road.
305x30-19" or 275x35-18" is the correct manner of expressing tire specs.
The new MICHELIN Pilot Super Sport tires are sticky right from the beginning. And they're expensive. Don't abuse them, respect them. I just put a set of them on my car prior to BAER rotor seasoning. They really stuck on 40 degree northern AZ roads during high speed stops.
Your warming temperatures could have an effect on your tune.
The PSS so far seem to be a perfect street tire for someone looking to drive their Vette hard, but not race track hard.
You're in the military...dates and times (and tire sizes) are written differently.
I also had drag radials that I could roast until they got toasty warm. After they were warm it was quite difficult to break them loose on the street. I had to get rid of the DRs since I couldn't stand the loose feeling they gave at high speeds. A bit un-nerving to have the a$$ end of the car wiggle when I changed lanes at better than interstate speeds.
The MPSS is a great tire in Dry & Wet. I have done HPDE's on them and they are better than any other 200 tw tire i have used. Not as good as an R Compound, but very good.
Ed
Ed
