What make those Supra's so fast?
Old 03-17-2012, 04:20 AM
flaagan
CF "Young" Senior Member
Support Corvetteforum!
flaagan's Avatar
St. Jude Donor '12
I'll say two things about my experience with Supras.
1) Two friends have them, one's busted all the time and held together like a junkyard heap. The other's a bit of a speed nut and has stripped the interior and such down like crazy, to the point his instrument cluster is held in place by zip ties. My '01 'vette, untouched, weighs less than his 'stripped out' Supra.
2) There is a running gag regarding Supras:
Q: What's the difference between 600, 900, and 1300 hp Supras?
A: Nothing, they're all 13 second cars.
Old 03-17-2012, 07:07 AM
99FRC Newb
99FRC Newb's Avatar
notice that most of those videos are from a roll. they have big turbos and from a roll, the lag isn't as noticeable. watch some videos from a dead stop and it'll be a different story. look at how much lag this one has
Old 03-17-2012, 02:32 PM
Dominic Toretto
Dominic Toretto's Avatar
These Supra threads are coming up a lot more now.
There are plenty of cars that you can MAKE faster than a Corvette. Hell you can youtube videos of Civics beating Vipers. Stock for stock C5s walk Supras all day and that doesn't even include C5ZO6s.
What makes those Supras so fast? Deep pockets.
-Alex
Old 03-17-2012, 02:36 PM
FYRARMS
FYRARMS's Avatar
Received 3,232 Likes on 1,589 Posts
Welcome to 1999 internet jokes.
If a Supra is "laggy" from a dead stop, it is the driver's fault. A driver who launches the car properly will launch extremely hard. Sticky tires and a good clutch? Yep...
http://www.youtube.com/watch?v=08Sftw6UyFE
http://www.youtube.com/watch?v=AaM1qCc7SCc
Old 03-17-2012, 03:14 PM
SacCityCorvette
Supporting Vendor
SacCityCorvette's Avatar
Location: SacCityCorvette.com in Sacramento Ca Join us on Facebook!
St. Jude Donor '12,'13,'15,'16,'17
Maybe I am wrong but it seems like they can make more power per cubic inch then our LS engines can.
__________________
Don't forget to check out our products at www.saccitycorvette.com
If you like our products, tell others! If not, tell us!
Old 03-17-2012, 03:18 PM
phinfan
phinfan's Avatar
Guys, there is really no mystery to it, there is a very reasonable explanation for everything.
I owned Grand Nationals for about 15 years, when you want to make a forced induction car faster, it is easiest to think of your engine as a air machine, and the the quicker, and more efficiently you move more air through your engine, the stronger it will be.
Turbos for the most part are the most efficient form of forced induction, super chargers spend too much HP moving the belt, and blower.
You also must understand "atmospheres", or pressure, or boost. One atmosphere is ~14.7 psi, and that is what we walk around in, and what the pressure of air is inside our normally aspirated engines.
Cars like my GN came from the factory making ~14.5 pounds of boost maximum, so at full boost, there was ~two atmospheres of pressure inside the manifold, going into the cylinders, making a 231 cu inch car produce power roughly equivalent to a car with 462 CI, as far as air going in and out.
I had friends that raced with over 30 pounds of boost, which is over three atmospheres of pressure, or 3 Bar i think.
Now this is a fundamental way of looking at it, and the way the car is set up, and what it can handle, has much to do with it, but if you are setting a car up for boost, it is a complete different method than setting it up a normally aspirated one.
The Supra, is over engineered, and from what i understand, able to take quite a bit of boost, even in its stock form, while the GN, although a great car, was engineered to do the most it could with a passenger car block.
Also, as the gentleman above me said, if you do not think you can make a turbo launch REAL HARD, you just have no experience with one, GN's just needed a loose torque converter, and a driver that new what he was doing, and they came off the line like they were shot out of a cannon.
Old 03-17-2012, 03:19 PM
SacCityCorvette
Supporting Vendor
Originally Posted by Mr.Bill
Because the guys driving the Corvettes need the driver mod.
Do you guys sell the driver mod?
Good one Mr.Bill!
Old 03-17-2012, 03:40 PM
Kman1971
Kman1971's Avatar
St. Jude Donor '12
VERY WELL STATED!!!!!!!!
Old 03-17-2012, 03:46 PM
SilentFright
SilentFright's Avatar
Location: Arlington Texas, originally from San Angelo, TX
Originally Posted by SacCityCorvette
Have you gone on YouTube and search Corvette vs Supra?
Those Supra's with their inline 6 cyl. turbo is kicking a lot of Corvette a$$!
Why??
Because boost is king! It doesn't matter how small the engine is when you are cramming the cylinders with 30psi from a monster turbo.
Old 03-17-2012, 04:25 PM
Ona mission
Ona mission's Avatar
St. Jude Donor '14
They are lauching hard and that is key to lower ET's,great 60 foot times. The corvettes are coming out very soft and that could be a function of gearing, traction and low T on the driver part.
A 12:50 on a car that launches that well doesn't really impress me, it's just not that much quicker then the c5,. It would be nice to see the trap speeds or a least be at the finish to see if the Supra can hold it's own on the big end.
Old 03-17-2012, 06:28 PM
FYRARMS
FYRARMS's Avatar
The top end is where Supras shine. Big turbo + high rpms = uber-high trap speeds.
Old 03-17-2012, 07:10 PM
Silverbullet00
Silverbullet00's Avatar
Location: Norman Oklahoma - The Only State in the Union with no Blue Counties!
Since there will always be cars fster than mine no matter what kind of car I have,,,,,, I'll drive America's Sportcar and never envy or bow to anyone!
Besides, ask a kid or a woman,,,Ricer or Vette,,,,nuff said!
Old 03-17-2012, 07:48 PM
  #33
rtpassini
rtpassini's Avatar
St. Jude Donor '11-'12
The interior dash setup on supras are just so damn ugly. especially the center part.
my friend is a big supra nut. had two different ones now. Without mods, its a pretty flat car. nothing special imo
Old 03-17-2012, 08:40 PM
  #34
phinfan
phinfan's Avatar
Well, as shown the Supra is a fast car, with the ability to be much faster.
As far as which cars I liked, that's a different story, I have nothing against them, or against Japanese cars, I drive a civic everyday, and WISH GM would make something as good.
It's all personal tastes, some do not like the z06 body style , I absolutely love it. I would have to say I have a far reaching taste in performance cars, love many of the Porsches, looked at a real 944 turbo S before buying my Z06, and really liked it too.
I ultimately chose the Z, and have no reservations about the choice, and as I am getting older, my stock Z is more than fast enough for me.
Supra's are nice cars though...
Old 03-17-2012, 09:19 PM
  #35
FYRARMS
FYRARMS's Avatar
Exactly. Ask either uneducated option.
Ricer? Perhaps you clicked on the wrong thread? This is about Supras.
Old 03-17-2012, 09:49 PM
  #36
JustinStrife
JustinStrife's Avatar
It's comparable with a 90's C4, but without all the digital crap.
Old 03-17-2012, 09:53 PM
  #37
FYRARMS
FYRARMS's Avatar
LOL! Not quite. The actual "aim towards the driver" layout is a similar design, but many cars use such a design. The quality and materials used in the Supra are way ahead of the old C4. Hell, I wish my C5Z interior had the same quality feel that my Supra had.
To What make those Supra's so fast?
Old 03-17-2012, 09:57 PM
  #38
rtpassini
rtpassini's Avatar
Not even comparable. The supras dash and gauges are so outdated its not even funny. the center console is big bulky and hideous. Everytime I got in it I couldn't understand how the same people who made the rest of the car came up with that crap.
the c5 dash and console is a million times better
Old 03-17-2012, 10:01 PM
  #39
rtpassini
rtpassini's Avatar
And the targa. just poor design
Old 03-17-2012, 10:08 PM
  #40
JustinStrife
The Supra came out 4 years before the C5. Compare it to the other cars of it's time. Corvette Interiors have been 'lacking' since about 1968.
Quick Reply: What make those Supra's so fast?
