** New Product, C5 Center Console Insulator **
#41
Added to next month's car budget. This would help keep my iPod a lot cooler than it currently is even after only a few minutes; my USB connection comes out inside the console.
#45
I placed my order today because I really need one of these to help cool my iPod down and prevent the error messages the heat is causing, but WOW are you guys sure proud of the boxes you ship them in at nearly 10 bucks for shipping. Don't forum guys get a break?
#47
Thank you for the order Ed
#48
I put this in my coupe not too long ago, and i can testify to the effectiveness. While driving around Sunday at about 85-90 degrees and sunny. When i opened the center console it was not even warm, whereas before the insulator,it would be hot as well as anything residing in there. Great product. Ken
#49
#52
I installed mine on Friday afternoon. After driving around on Saturday I checked my iPod to see how well the insulator was working and the temp was double digits lower. Usually it gets so hot that I can barely hold it, but now it's staying plenty cool enough.
#53
Thank you for posting Corvette_Ed
#55
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23
Oldtimer
Thanks for the instructions !
I bought mine about a month ago and I've looked at it many times trying to figure out if it goes in or under the Console on my C5. Thank fellas for the heads up. It goes inside the console.
#56
** This Product fits all C5 Models 1997 thru 2004 **
Are you searching for a low cost and easy method to reduce the temperature inside your center console? Reduce your interior console temperature to a more manageable level by using our easy to install C5 Center Console Insulator.
Installation is just a matter of pressing the Console Insulator into place. Laser cut for a perfect fit. 1/4 inch insulation covered in black felt to match the stock interior console. Experience a noticeable reduction in interior console temperature with an easy to install and inexpensive alternative.
Order on our website at http://www.topflightrepro.com/corvet...products.shtml
