Blown engine -- help finding shop near Philadelphia
I blew the engine after installing an oil accumulator (ironic) due to a faulty oil return hose that developed a kink, leading to oil starvation. That's my theory at least.
Sounded like the issue was lower end, metal rattling around, my guess is a rod bearing that slipped but who knows.
I want to pull the engine and send it out to a shop to do a stroker crank, cam, pistons, and maybe an LS6 head if I can find one (+ any other suggestions).
Any suggestions for a shop within a few hours of Philadelphia?
Thanks as always
Thanks as always
I'd suggest East Cast Supercharging in Cream Ridge NJ. Dour Ring - the owner does spend a little time on the forum, so he may see this, but I'd suggest going to see them, and discussing what your looking t have done...
https://www.thevetteshop.com/car-res...e-pennsylvania
Bucks County, PA maybe an hour north of Philly... Been around a long time. GOOD LUCK with the car...
Received 2,245 Likes
Sounded like the issue was lower end, mettle rattling around, my guess is a rod bearing that slipped but who knows.
Thanks as always
Thanks as always
https://www.corvetteforum.com/forums...shop-here.html
