Do i need a tune
Do i need a tune
My exhaust pipes are really black and sooted up and I assume it is from running way to rich.It is a 2001 C5 bone stock A4.Do I need to get a tune to correct this.I submitted this in the tech forum but got no response.I will appreciate any help.Thank you.
FRED
FRED
Received 1,762 Likes
No not really these ls1 motors just run rich if you want to look at it by the pipes being black. Better rich than lean in these cars. If it is bone stock and being a 2001 put a few cans of inj cleaner in it to help if it is sticking some on those. sea foam is the best... Again if 100% dont worry about it after the sea foam inj cleaner.. Robert
You should get a tune anyhow. You won't believe the difference it makes in a A4.
Received 19,414 Likes
'20-'21-'22-'23-'24
Thanks everyone.FWIW I only use Chevron Premium and I don't drive in the winter or at night.I also have a catch can installed but I get very little oil in it.
FRED
FRED
