Exercise that passenger window!
Old 01-24-2012, 10:13 AM
Dave68
Dave68's Avatar
Default Exercise that passenger window!
Just a word to the wise - If you don't ever use your passenger window, expect to not work, some day. I not only put the passenger side window down every time I pull into the garage, but I also try to reach over and use its window switch every now and then.
I recently cleaned the passenger side window switch contacts in my 89 Mazda and now the window raises and lowers noticeably faster. You know the old saying - Use em or lose em!
Old 01-24-2012, 10:51 AM
MSG C5
Support Corvetteforum!
MSG C5's Avatar
Received 2,681 Likes on 1,482 Posts
2018 C5 of Year Finalist
Good advice. I installed the window valet as it makes life easier for us vert owners, however I should use the passenger door controls more often. I have probably only pressed those buttons a dozen times since 2004.
Old 01-24-2012, 11:03 AM
runner140*
runner140*'s Avatar
Thanks Dave, good point.
Old 01-24-2012, 11:11 AM
$$$frumnuttin'
$$$frumnuttin''s Avatar
Location: Should this thoughtful, valuable contribution meet with no acknowledgement or 'thanks' this post----
good advice...the window valet is great for coupe owner's too...lots of times I want to put something on the passenger seat when shopping...it's way easier from outside the car, so I use the window valet to create an opening.
Old 01-24-2012, 11:37 AM
VETJAZZ
VETJAZZ's Avatar
Interesting. Thanks for the suggestion.
Old 01-24-2012, 11:56 AM
waupachino
waupachino's Avatar
This is good advice I have a 00 GTP that if I don't use the passenger Window regularly I have to give it a hit on the door panel to get it to work.
Old 01-24-2012, 02:37 PM
99 VET
99 VET's Avatar
Oldtimer
St. Jude Donor '13
Tks DAVE68 for the good tip. I would like to add that I turn on & off the head lights as I don't do a lot of night driving...
Old 01-24-2012, 02:58 PM
DeeGee
DeeGee's Avatar
Thats the good thing about owning a Vert. Every time the roof goes down, so does the window
Old 01-24-2012, 03:07 PM
Dave68
Dave68's Avatar
I would think the same is true of the passenger power seat controls and since I rarely have anyone in my C5, those controls almost never get used, either.
Dave
Old 01-24-2012, 03:11 PM
Dave68
Dave68's Avatar
When I had my 68 vert, I'd leave its hardtop suspended in the garage for the whole Summer. When I drove to work in the morning, I'd leave the windows up and sometimes turned on the heater. Of course, those windows were "crankers", so I didn't worry about electrical contacts getting corroded!
Old 01-24-2012, 04:41 PM
killain
killain's Avatar
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23
Oldtimer
Default Storage and rust or ride ?
Great point, I had some trouble with one of my headlights, it wouldn't go up and down with the other. . I ran them both up and down five times and they work perfectly now. I have to forget about not using during the winter, I ain't taking with when I pass on. And that too far off. . .
Old 01-24-2012, 05:58 PM
imavettegirl
imavettegirl's Avatar
i open and close my glovebox every week to make sure it does not get stuck closed.
Old 01-25-2012, 12:19 PM
maroman88
maroman88's Avatar
windows are open pretty much every time the vette moves
Old 01-25-2012, 12:28 PM
m6 c5
m6 c5's Avatar
Easy fix is to have a passenger
Old 01-25-2012, 03:21 PM
Dave68
Dave68's Avatar
Except when the passenger is a young kid - then the window motor will get worn out!
Old 01-25-2012, 04:24 PM
Z06ster
Z06ster's Avatar
Originally Posted by Dave68
Just a word to the wise... I ..put the passenger side window down every time I pull into the garage...
I do this everytime... before I put the car in the garage, I roll the windows down and up.
Old 01-25-2012, 04:31 PM
hiyosilver01
hiyosilver01's Avatar
Good advice, but I am afraid it is a little too late for me. I am currently experiencing the passenger side window problem.
To Exercise that passenger window!
Old 01-25-2012, 04:45 PM
joestrazz
joestrazz's Avatar
Yes, when I bought my Vette last August the passanger window was stuck in the up possition, ended up costing my around $400 in parts/labor to fix
Old 01-25-2012, 04:46 PM
209TIME!!!
209TIME!!!'s Avatar
Man I'm sorry guys but I don't by into this thread....if its going to break its going to break. (jmo) what do I know anyway.....lol
Old 01-25-2012, 05:25 PM
m6 c5
m6 c5's Avatar
Yea Im not so sure if it helps either but mine gets used enough anyways.
Quick Reply: Exercise that passenger window!
