[Z06] Trunk not popping up enough?
Just picked up an 04 CE Z06 and getting acclimated to the Vette community. When I hit the trunk release button on the fob or the dash, the deck lid pops up but not high enough to get a finger at it to open it. Is this a common problem? I would assume that when the latch is popped, it should pop the deck lid high enough so it can actually be opened.
Night Owl for life
Received 3,247 Likes
Welcome to the C5 platform, you sure picked a good one
Here's a fix for your issue
https://www.ebay.com/itm/30518087826...Bk9SR_bFm9arYw
And here's a thread if you want to read more about it
https://www.corvetteforum.com/forums...er-spring.html
The following 2 users liked this post by jdmvette:
FLYINBY (02-06-2024),
yellow2007 (01-31-2024)
The Z06 shares the convertible trunk lid. I have this page bookmarked to eventually tackle on my Z06: https://www.corvetteforum.com/forums...up-enough.html
Received 19,285 Likes
'20-'21-'22-'23-'24
Yes, what you describe is a common problem and adding a set of those springs does make a difference. Should work like new once installed.
I read this thread and all of the linked threads. This one fixed my problem with no extra parts and no visible changes to my car,: https://www.corvetteforum.com/forums...up-enough.html.
Tron Z (01-31-2024)
DirtRoad (01-31-2024)
The correct fix is put new struts on. They are not expensive and you may still have the original ones on. My 02 had original on the deck lid and read cover. By replacing them it was amazing how worn out they were.
New struts and lubing the latch worked perfectly on my Z. Didn’t really like the look of any of those spring kits.
the link above about adjusting the factory spring under the carpet sounds promising as well.
G_Loc (02-09-2024)
If the trunk lid bangs you in the head in a gentle breeze, you definitely need new struts/gas springs.
It makes sense to periodically lubricate things regardless of whether the struts are good, or not.
My gas springs "only" lasted twenty years and the replacements are cheap.
^ This
The truth is the struts are failing.
You can put a spring on or you can fix it right. Same with failed struts you can prop it up or fix it right.
‘Keep in mind some struts can be poor quality or the wrong pressure too I’d you do not take care yo get the correct ones. Just because they are the right size does not mean they are the right pressure for weight. SUV tailgates have had issues here. Many struts are not able to hold the heavier parts when they may have been made for a truck cap window.
Use care in choosing.
