Help, Dealership trying to rip me off
Alright so I brought my car in on Tuesday to have the harmonic balancer replaced and my A/C fixed at a local GM dealership. Now as many of you know, to replace a harmonic balancer the steering rack has to be moved or removed as well as the power steering pump. Well I ended up paying about $2000 for the balancer install and for them to replace a leaking compressor which was fine. So I picked the car up on Friday and go to drive off the lot and notice that the power steering isn't working when the engine is at idle, its alright when I rev it up and try but other wise, nothing. Now I went in and told the service guy that had been helping me and basically their conclusion was that it wasn't their fault, even thought they had just been messing with the power steering. And they drove the car 1.8 miles after the install (I reset the trip counter) and claimed they never noticed. The service manager basically said they would give me a rental and pay for labor but I had to buy the $400 part. Which is rediculous seeing that there never even was a problem when I brought the car in. I have the rental till Monday while they check it out.
Well as you can tell I'm very frustrated and just wanted to hear what you guys have to say about this whole power steering pump issue.
Received 19,235 Likes
'20-'21-'22-'23-'24
If it was working fine when you brought it in, it should be working fine when you picked it up. If the service manager won't accept responsibility, talk to the dealership owner.
What $400 part?
Remember it is speed sensitive steering, so it should be real easy at idle movement and stiff at speed.
It is amazing how car related businesses do business, the very same people you count on to maintain your business operation, they will purposely screw and do it with a straight face.
I hate it when incompetent jerks what to avoid any responsibility. Looks like the idiot technician either failed to refill and cycle the steering pump and cylinder. I don't see much he could have assembled wrong in putting it back together. Maybe just check the fluid level and see if that's the problem.
When you made the problem known to the Service department they should have immediately taken the car and investigated the trouble.
What $400 part?
At idle there was no power steering at all. The car might as well have not been running.
What do you mean by cycling the steering pump and cylinder? I don't know much about how the steering works.
St. Jude Donor '09-'10, '14
I've never had a dealership take responsibility when something like this happens. I noticed my torque converter was slipping on my Ram while still under warranty. I received a coupon for a tranny service that specifically stated they change fluid/filter and perform an operational test. Picked it up and they said all was ok. So I thought I was imagining things.
I took it back a few months and 2K miles later and now all the sudden they said the tranny was shot. The warranty ran out within this 2K miles. When I ask why it wasn't caught the first time they told me they don't do a system check on a tranny service. When I ask them about their coupon they sent out they denied sending it out to me and I was making it up.
After a few words with the service manager I was ask not to come back to Dodge City Motors. So I spent 2K at a tranny repair shop. I have another story about an AC service that went the same way at another repair shop as well.
So unless you are prepared for a fight you are probably receiving about all you will.
Yes, I think they did something wrong. That's the problem with having a car that is no longer being manufactured, it's difficult to find someone who knows how to work on them even though they aren't really that old. At least that's been my experience anyway.
cesssna10
I have found if your car is out of warranty find a private
repair shop, particularly one that works on high performance cars like corvettes. They usually are more reliable, cheaper and more
customer friendly. Check with your local corvette club or with vette
magazine to find one.
Received 1,673 Likes
That power streeling problem was caused by them but don't expect them to take any resposibility!
and thats why their nicknamed "Stealerships"
Our Corvette club is sponsored by a local dealer and they not only do a great job, they stand behind their work. Not all dealers are myopic and they will do what is right.
I think it is important to let any repair shop know and agree that a car is in good working order before they take the vehivle in their possession. If I'm getting tires changed, not only do I make sure they know the wheel condition, I take a picture. Years ago I had some work done on my 65 at a large dealership in Alexandia Virginia. After paying the bill I drove out of their lot and discovered they hadn't bled the brakes. I found that raising a bit of hell in the show room got pretty good attention from them..If you get my drift.
I'm sure all you do is turn the steering wheel all the right till it stops then all the way left till it stops. Do this to clear the air in the lines when they put it back together. I think that purges any air out of the steering pump and lines.
At least I think it does?
