Gauge Bezel and Trim Rings - INSTALLED!!
Guest
Posts: n/a
I finally got around to installing the gauge trim rings and hydrocarbon gauge cluster bezel that has been sitting on the bench for about a year now. One of my customers' (Jack Tipton) offered to do it for me but I had some time off over the holidays and tackled the job myself. It is a very easy install. One trick I learned about the trim rings is to get the flow control superglue so that you can just put a pin point sized drop on several places while holding the ring in your hand. Then all you have to do is put it in place and hold it for a few seconds. No mess. Steering wheel is next (It also has been sitting on the bench for a year) Stay tuned
St. Jude Donor '11-'12-'13, '15, '16-'17-'18-'19
Very nice mod
I liked the rings when I had them on my old 97, but even though I used good super glue, my rings would fall off after a few months, especilly in cold weather.
Not sure why that was.
Received 19,369 Likes
'20-'21-'22-'23-'24
Looks great - too bad the C5 didn't come with them on the car from the factory.
[SIZE="4"]....One trick I learned about the trim rings is to get the flow control superglue so that you can just put a pin point sized drop on several places while holding the ring in your hand. Then all you have to do is put it in place and hold it for a few seconds. No mess....
You did a nice job. If you're for hire to re-do mine, send me a PM.
C5 Gauge cluster mods, are, to me, one of the most rewarding interior mods. I have done two (my '99, and my wife's '01) and they turned out great. Thanks to the abundance of info here, I had almost no difficulty in doing them myself.
Congratulations on a job well done.
Wife's '01. Faces, trim rings, and painted cluster/dash housing.
My '99. Painted entire cluster/dash housing.
Prep with denatured alcohol is the key to the rings staying on forever...pinpointing the super glue is the other key.
Had the same thing happen to me on a bumpy road, I searched the forums here and seems like this is a somewhat common issue with the super glue. The recommended fix was to use black silicone adhesive, it maintains it flexibility. Did that a couple of years ago and so far no issues.
Received 1,762 Likes
99mallett,
How do you like the white face gagues? do the needles hang at all? thanksThanks
sorry for the hijack
the trim rings looks awesome, I am sure they are in my future!
I have them on the 4 small ones now, Had them on the 2 big one,s but like you are saying here for some reason getting hung up at some point in the travel up and down on it. I pulled the two big ones off. If any one puts these on the car DONT PULL THE PINS OUT OF THE GAUGES.
DAYUM that looks really slick! I love the idea of either carbon fiber or painted, id love to have a green set-up like the red one in the pics. just have no clue how to do it or how much $ it costs. details?
