[Z06] Instant horsepower in a box available at GMPARTSHOUSE.com
Old 10-22-2011, 08:29 PM
patrickt
Premium Supporting Vendor
patrickt's Avatar
Default Instant horsepower in a box available at GMPARTSHOUSE.com
Why buy from us? All predators will be reflashed with the latest software and firmware before leaving our warehouse. That means you do not have to buy the update cable and update it yourself.
Diablo Sport Predator
The Predator is a state-of-the art, high performance tuning flash programmer in a sleek handheld design. Once connected to the vehicle, the Predators internal computer recognizes the vehicles PCM and automatically picks the proper tuning files designed specifically for that PCM. Inside the Predator's memory are the actual tuning files that optimize spark timing and air/fuel ratio curves. The transmission parameters are remapped to improve the shift characteristics such as shift firmness and shift points. Unlike other 'tuners', DiabloSport's programming is performed in very small increments throughout the entire RPM range, for a smoother, wider and a more predictable power delivery. DiabloSport engineers spend many hours on the dyno, street and track to ensure the tunes provided with the Predator are the best they can be.
1999-2003 Specific
U7198 Stock Vehicle Tunes:
Performance Tune: Designed to add power and torque using premium fuel.
Factory Tune: Designed for users who wants to adjust parameters using the factory tune.
U7198 Specific Features:
Click here to see more details on how to adjust parameters.
Timing Table 1000-1800rpm (+/- 20%)
Timing Table 2000-4000rpm (+/- 20%)
Timing Table 4000-7000rpm (+/- 20%)
Fuel Table 2000-4000rpm (+/- 20%)
Fuel Table 4000-7000rpm (+/- 20%)
Idle (+ 500rpm / -300rpm)
Speed Limiters (Trucks Only)
Rev Limiters
RPM Shift Points
MPH Up and Downshifts
Shift Timing
Shift Pressure
Cooling Fan ON and OFF temperatures
Re-Calibrate Speedometer for Gear and Tire Size Changes
Torque Management abuse mode time limit ON/OFF
% torque reduction vs. RPM ON/OFF
Upshift torque reduction (all gears) ON/OFF
Adjust for different injector size
Adjust COT enable temperature
All standard DiabloSport Predator features
2004 Specific
U7193 Stock Vehicle Tunes/Horsepower Gains:
Corvette 15-20 rwhp 20-25 ft/lbs
U7193 Specific Features:
Timing Table 1000-3800rpm (+15/- 20%)
Timing Table 4000-4800rpm (+15/- 20%)
Timing Table 5000-7000rpm (+15/- 20%)
Fuel Table 1000-3800rpm (+/- 20%)
Fuel Table 4000-4800rpm (+/- 20%)
Fuel Table 5000-7000rpm (+/- 20%)
Rev Limiters
RPM Shift Points
Shift Timing
Shift Pressure
For all
Price 289.99
To order 1999-2003 use part# DSPU7198
To order 2004 use part# DSPU7193
Simply click here and enter the part number above
Programmer, DIABLO SPORT TRINITY
Trinity Features:
Comes pre-loaded with multiple tunes for your vehicle including Economy, Factory, Performance, Towing, Extreme, CAI Tunes, Pulley Tunes, and many more (tune selection may vary from vehicle to vehicle)
Built in Diagnostic Tool-save hundreds in dealership charges reading and clearing your own trouble codes (check engine lights)
With over 100MB of onboard memory log/record hours of data
Virtual Gauges-customize your own gauge layout
View and record dozens of gauges at once
Tune multiple supported vehicles (only 1 at a time).
Supports custom tuning-accepts up to 5 additonal custom tunes
The most adjustable parameters on the market including speed limiter, tire sizes and many more!
Virtual Dragstrip-computes 1/4 mile, 1/8 mile, 0-60, and 0-100 track times. Option to start from a reaction tree or once accelerator is engaged
Analog input/output to control external devices such as the DiabloSport Extreme PowerPuck and DiabloSport EGT Module
Set up your own gauge alarms/shift lights using the Trinity's LED lights
Control the Extreme PowerPuck's power levels using the Trinity's interface
High Resolution 320x240 Full Color Touch Screen
Price 519.99
To order 1999-2004 use part# DSPT1000
__________________
Patrick Trageser
CULTRAG Performance
Your one stop source featuring the true experts for all GM Parts and Accessories, Lloyd mats, SLP Performance and Hawk Brake pads!
Order Your GM Parts at www.CULTRAGfactoryparts.com
patrick@cultragperformance.com
1-484-334-8833
patrickt is offline
Old 10-25-2011, 10:32 PM
patrickt
patrickt's Avatar
place your order today
patrickt is offline
Old 10-29-2011, 11:20 PM
patrickt
patrickt's Avatar
patrickt is offline
Old 11-01-2011, 11:07 PM
patrickt
patrickt's Avatar
order yours today
patrickt is offline
Old 11-03-2011, 10:12 PM
patrickt
patrickt's Avatar
increase today
patrickt is offline
Old 11-07-2011, 10:31 PM
patrickt
patrickt's Avatar
place your order today!
patrickt is offline
Old 11-14-2011, 09:08 PM
patrickt
patrickt's Avatar
your one stop for all your GM and aftermarket needs
patrickt is offline
Old 11-17-2011, 08:48 PM
patrickt
patrickt's Avatar
the deals never end
patrickt is offline
Old 12-04-2011, 09:27 AM
patrickt
patrickt's Avatar
We are your number one source for that car nut this holiday season
patrickt is offline
Old 12-17-2011, 09:30 PM
patrickt
patrickt's Avatar
not to late to complete that holiday shopping list!
patrickt is offline
To Instant horsepower in a box available at GMPARTSHOUSE.com
Quick Reply: [Z06] Instant horsepower in a box available at GMPARTSHOUSE.com
