low oil level message
Old 12-03-2011, 09:17 PM
Hayekfan
Hayekfan's Avatar
Default low oil level message
New to me 2000 coupe (I will be posting pictures), low oil level comes on. I check oil, add a quart, drive several miles. The message comes on again. Check oil, its full. message still coming on.
I've only driven about 20 miles since adding oil. Why the repeat in the warning?
Wayne
Hank Mills (01-01-2018)
Old 12-03-2011, 09:51 PM
Hayekfan
Hayekfan's Avatar
oil pressure guage is working properly, read 40+ at road speeds.
Old 12-03-2011, 10:26 PM
3musky3
Support Corvetteforum!
3musky3's Avatar
the sensor is just a smallfloat on plastic and can stick easily have seen this after oil changes. also i think you might have to go through a couple drive cycles before system resets
Old 12-03-2011, 10:32 PM
Hayekfan
Hayekfan's Avatar
Thanks.
Old 12-04-2011, 09:49 AM
rws.1
rws.1's Avatar
It is a blue colored sensor on the back passenger side of the bat wing oil pan.
About $17 part. Easy to change when the Vette is in the air or on stands.
The other potential problem is broken or melted wiring to the sensor.
The following 3 users liked this post by rws.1:
Hank Mills (01-01-2018), msandym (12-30-2017), Venom602 (12-21-2020)
Old 12-04-2011, 08:17 PM
Hayekfan
Hayekfan's Avatar
Great picture, thanks.
I won't be able to drive the car till Weds. I'll see then if it goes away after several cyles.
Old 12-05-2011, 08:01 PM
Hayekfan
Hayekfan's Avatar
Took the Vette out after work to run some errands. No low oil level message. I guess it needed a few more cycles and a 24 hour rest.
Thanks for the help.
Old 12-05-2011, 09:39 PM
Oh 2 Fun
Oh 2 Fun's Avatar
St. Jude Donor '09, '13, '15
RWS.....thanks for showing us where the sensor is. I'll remember that!
Always something useful here!
Old 12-06-2011, 11:33 AM
Dominic Toretto
Dominic Toretto's Avatar
The few times I received the message I added a quart and it did not come back on until I was actually low again on oil. Interesting though.
-Alex
Old 12-06-2011, 11:37 AM
RetiredSFC 97
RetiredSFC 97's Avatar
St. Jude Donor '09-'10, '14
Yeah mine did that too. But it finally went off.
Old 12-15-2011, 12:39 AM
3musky3
3musky3's Avatar
had some free time at work and looked up info on low oil message per GM SI doc #609457
conditions for clearing low engine oil level message start engine and allow to reach operating temp (194*f). turn off engine. ignition must remain off for minimum of
one hour. engine coolant temp should decrease -18*f. when you turn the ignition on the conditions for performing the test should be met and the low oil message clears.
Also this is interesting. conditions for illuminating the low engine oil level message
The pcm detects a low oil level condition for 3 ignition cycles. guess i am going to have to see what gm calls an ignition cycle now?
this is for a 2000 vette other years are prob. different
Old 12-15-2011, 01:04 AM
damilleniumboy
damilleniumboy's Avatar
Wow, I just learned something new today, thanks.
AkGrown71_C5 (02-26-2022)
Old 12-15-2011, 01:55 AM
luckyirishguy
luckyirishguy's Avatar
Very helpful pic
Old 11-16-2016, 07:11 PM
Thom2play
1st Gear
Thom2play's Avatar
To all, thanks for the info. I just bought a 2000 convertible today after test driving the car last week with no issues, I take possession and get the low oil level message. Car is super clean with only 24000 miles, so I didn't panic. Checked dip stick and it looked maybe a quart low. Stopped and added a quart.,Started on my way home and it kept cycling on although the oil pressure looked normal. Now I understand the concept of "cycles", so hopefully I won't see it tomorrow.
Old 11-16-2016, 08:21 PM
nvusgt
nvusgt's Avatar
Quick question: how low is the level when the warning shows up?
I seem to get the message about twice every oil change cycle. So I fill it up the appropriate amount. I suppose the proper question would be is that normal; adding about 2qts between oil changes.
Old 11-16-2016, 09:29 PM
Murray Anderson
Murray Anderson's Avatar
Short answer is no, it's not normal.
No oil should be needed between changes if it isn't burning it or leaking it.
Old 11-16-2016, 09:41 PM
Corvette#2
Corvette#2's Avatar
If you drive it hard, some years are prone to oil usage. I believe 99, 00, and 01 are especially known for it.
My 2000 has varied between using a little and a decent amount of oil. I've done 5 oil changes. Mobil One 3 times, Penzoil Platinum once, and Mobil One High Mileage once. And It's needed anywhere from 2 quarts over about 4-5k miles (PP), to the current fill (Mobil One) where I've only added .5 quarts and the oil life meter is already down to 40%. It seems to be using less but it's probably my driving habits. If I remember correctly, off throttle high rpm operation allows more oil to get past the rings. I check my oil at least once a month. I've never seen the low level lamp go on.
To low oil level message
Old 11-19-2016, 04:21 PM
Fatbob
Fatbob's Avatar
If I waited for the dic to tell me to change oil, it would be near 10,000 miles. Maybe the cars computer says it is OK but I couldn't wait that long. most of my miles are highway miles with a few miles of feeling the performance I bought it for. After 5000 when I changed, I was not close to having to add a quart.
Old 11-20-2016, 10:07 AM
ArtGle
ArtGle's Avatar
Good Morning, and a "Happy Sunday" to all. My 1999 Coupe.
I just got my very first "Low Oil Level" message a couple of days ago.
But since I hadn't touched the oil since a year ago, when I did oil and filter the day before storing her, in Boston (November), and she spent 6 months stored, I guess we won't count that time.
Brought her out April 1st, as usual, and THE HELL RIDES began.
I could look back through slips and photos to count the mileage, but too lazy this morning.
Let's just say "Albany, Bangor, Long Island, Scranton, Brattleboro", to name a few.
Not to leave out Corvettes at Carlisle.
And finally in Sept., THE MOVE.
Drove her from Boston to Shelby, NC, and 'just because', on to Anderson, SC to visit a Corvette Nation buddy. Then he and I drove down to Georgia JUST BECAUSE.
Back up to Kings Mountain, NC, and a LOT of local driving.
With all that, she was down a half a quart (maybe a tiny bit more).
So, I'm happy with "OIL LOSS", considering all the HIGH SPEED TRAVELING I've done this past year.
Did the oil and filter yesterday and drove her around within a 50 mile circle, and no more message.
Old 11-28-2016, 02:25 PM
danny99
danny99's Avatar
Received a 'low oil' on DIC just now ..short ride to work, 2002, 25k miles. Checked the dipstick and it's full... what gives? maybe just a false alert? pls help!
Quick Reply: low oil level message
