Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 General
Register Forgot Password?
Register Albums Search Today's Posts Mark Forums Read FAQ
Search
C5 General
General C5 Corvette Discussion not covered in Tech Sponsored by
Bud's Chevy
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-30-2011, 12:39 PM   #1
robertlthomson
CF Senior Member
robertlthomson's Avatar
Default Dash lights...hard to replace?
The Fuel and Gages lights, #'s 1&2 have been "flickering" lately. Are they difficult to get to and replace? Should I replace all of them in that panel while there? Thanks for the help.
robertlthomson is offline   Reply With Quote
Old 11-30-2011, 02:26 PM   #2
whitesmokels1
CF Senior Member
whitesmokels1's Avatar
Markus Perry
There are actually two uv lights, one on each side of the cluster that light the gauges, the numbers on the gauges are a special paint that glows under the lights.
Not sure where to get them or how to replace.
whitesmokels1 is offline   Reply With Quote
Old 11-30-2011, 02:58 PM   #3
robertlthomson
CF Senior Member
Wow, I did not know that. So I wonder why just the two are on sometimes and other times not? Gremlin???
Old 11-30-2011, 05:48 PM   #4
Toolmandbq
Junior Member
Toolmandbq's Avatar
It could be possible that your multifuction switch is the problem. I had my dash lights go out and hit a small bump and they when on. Repaired the switch myself and it has been good for the last 2 years. This link is what I used to fix the problem: http://forums.corvetteforum.com/c5-t...f-replace.html
Taking the switch out is not to hard.
If you are going into the gauge area I used these steps to take it out. http://www.vetteessentials.com/instr...zel_howto.html
I am changing all the switch bulbs out for LED bulbs and since I have the gauges out any way I am going to add the rings to the gauges.
Toolmandbq is offline   Reply With Quote
Old 11-30-2011, 07:06 PM   #5
corvettezman
CF Senior Member
St. Jude Donor '11-'12-'13
Support Corvetteforum!
corvettezman's Avatar
I am pretty sure you have the wrong info since I have had my cluster out in the past.
Although the 2 UV light bulbs are there to enhance the lighting, there are bulbs back behind the individual gauges and a few behind the Tach and MPH clusters. Those can burn out and dim that specific part of the cluster even though the UV light could possibly be working.
corvettezman is offline   Reply With Quote
Old 11-30-2011, 07:07 PM   #6
BWF07
CF Senior Member
St. Jude Donor '11
Oldtimer
BWF07's Avatar
/jack.tipton.16
You will have to remove an disassemble the gauge cluster to get at them, which means starting with the removal of the center console to start with. It should take you about a hour to get it apart and the same to put it back together.
BWF07 is offline   Reply With Quote
Old 11-30-2011, 07:34 PM   #7
whitesmokels1
CF Senior Member
Markus Perry
Those are for the warning lights. The gauges are lit only by the UV lights.
Old 11-30-2011, 11:39 PM   #8
damilleniumboy
CF Senior Member
damilleniumboy's Avatar
You should re-do your "DIC" lightis with LED's. Here is the link. My #1 and #2 button also went out about a month ago, so I'm going to replace all of my dash, door, and HVAC stock lights with blue LED's.
http://www.toquez06.com/led.html
damilleniumboy is offline   Reply With Quote
Old 12-01-2011, 08:40 AM   #9
robertlthomson
CF Senior Member
Wow that really does look good, great suggestion.
Old 12-01-2011, 09:21 AM   #10
mre1974
CF Senior Member
mre1974's Avatar
This. ^ ^
mre1974 is offline   Reply With Quote
Reload this Page Dash lights...hard to replace?
Tags
1999, button, c5, change, corvette, dash, hard, hvac, instrument, light, lights, panel, replace, replacement, replacing
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
