[Z06] Leaky Z06
Old 11-27-2011, 03:03 PM
C4Scoreand7YearsAgo
C4Scoreand7YearsAgo's Avatar
Default Leaky Z06
I'm in the market for a Z06 and I looked at one yesterday and the bottom of oil pan was wet with oil. It wasn't dripping or anything, just a light layer of oil covering it. I couldn't tell where it was coming from. How normal is this for a 10 year old Z? Would you buy Z with a very slight oil leak?
Old 11-27-2011, 05:16 PM
n00b
n00b's Avatar
mine has no oil on the bottom nor does it leak
Old 11-27-2011, 07:25 PM
JETninja
JETninja's Avatar
WA Events Coordinator
Mine had a few drips I noticed after I brought it home. (got it last August) turns out the Oil filter was not very tight....No more leaks...
Old 11-28-2011, 12:03 PM
pluslt
pluslt's Avatar
Mine does not leak a drop as far as I've ever seen. And with stamped concrete underneath me it would be easy to see.
As for me, no I would not buy a car with an obvious leak. Too many out there without issues to buy one that already has evidence of something. Could be that the owner knows there's a leak and cleaned everything up before you came to look at it and what you see is just the tip of the iceburg. Could be nothing, could be something.
Good luck.
Old 11-28-2011, 12:07 PM
mph1972
Support Corvetteforum!
mph1972's Avatar
Cruise-In VIII Veteran
St. Jude Donor '07
Sounds like a slow oil pan gasket leak. I would clean it up really well with some brake cleaner or something like it and drive it a few days and see what happens. Could better determine what it is. That is, if you buy it.
The gaskets aren't too expensive through ROCK AUTO or PARTS TAXI, but the upper pan gasket will be a PITA to swap.
Old 11-28-2011, 02:39 PM
CordMcNally
CordMcNally's Avatar
There's several things it could be:
1.) Oil Pan Gasket - pretty rare for them to leak, usually they just need retorqued back down. An easy fix.
2.) Oil Filter - most likely loose if it's leaking. Retighten it.
3.) Oil Pressure Sender - mine leaked and it ran down the back of the engine into the area you're describing. This is the harder fix out of the 3 but it still isn't a tough fix. Hell, you'll probably have to do this fix at some point while you own a Vette anyways.
4.) Rear Main Seal - this is the least likely and also the most time consuming to fix. It's a cheap part but there's a lot of labor involved in replacing it. Again, this is pretty rare on our cars.
I wouldn't rule out a vehicle just because it has a few leaks. Most leaks are minor and very easy to fix. I'd use it as a price negotiating tool if you're otherwise interested in the vehicle.
Old 11-28-2011, 10:26 PM
Ngineer
Cruising
Ngineer's Avatar
Default May not be serious
My '03 Z06 had only 4,461 miles on it when purchased. The oil pan had a light oil film from gasket leak probably due to sitting. Gaskets replaced, no more leaks there now with 9,500 miles on it.
Rear axle seals began to leak too. Replaced at about 6,550 miles. Fine now. Point is that cars with little use develop leaks. Is this a possibility for the car you're looking at?
Old 11-29-2011, 12:04 AM
C4Scoreand7YearsAgo
It had fairly low miles, which I think probably contributed to the leak. It was pretty minor, but did look like it could be from the oil pan gasket, and probably just needed to be re torqued. Its a moot point now because it sold to someone else. I do appreciate the info though, since I'm still in the market and now have a better idea of what to expect.
Old 11-29-2011, 01:09 PM
aquachuck1
aquachuck1's Avatar
Default Seal
Oil pan was wet on my 02 Z @60K......I checked it out and it turned out to be the oil seal on the timing chain cover.
Old 11-29-2011, 06:43 PM
BLKWDWZ06
BLKWDWZ06's Avatar
my advice, have it cleaned and follow the trail
Old 11-29-2011, 10:52 PM
Xx_Black-out
Xx_Black-out's Avatar
St. Jude Donor '08-'11-'12
My '03 doesn't have any leakage...I agree with the above. Clean it and re-check.
...and @ your username
Old 04-06-2013, 10:52 PM
bigblock1974
2nd Gear
bigblock1974's Avatar
Which gaskets did you replace?
Old 04-06-2013, 11:28 PM
Ngineer
Cruising
Ngineer's Avatar
The upper and lower crankcase gaskets (required front cross frame removal). That stopped leak on crankcase then. Now, leaks again. Not sure what the problem is. Looks like could be crankshaft front seal. Car going to certified Corvette tech tomorrow.
Previously: replaced differential seals on both sides (only leaked on one side). Hydraulic clutch slave unit failed. Replaced it and installed a Monster clutch with lightweight billet flywheel. Hydraulic slave unit for clutch has improved seal design over the original part. Everything there (clutch) seems fine now.
Driver side rear axle spewing what appears to be black grease. Looks like a molybdenum disulphide type EP grease. Mechanic will evaluate this too. I'll update thread when I know what's going on with the crankcase oil leak and with the rear axle grease problem.
To Leaky Z06
Quick Reply: [Z06] Leaky Z06
